x 8322
Re: I am an Activaist-v6 and suffer AX-isum with a touch of CX TurboGTI'itus
CX-cellent :)
x 1988
Unread post by Stickyfinger »
Keeping at it whilst the sun shines and stuff in the engine bay dries quickly.
Slam-panel rubbed and painted (zinc and first silver top coat to protect)
Spare wheel plate refitted, wheel cleaned and painted, tools and brace also.
Various pipes cleaned, rust-eater, painted or waxed, many pipes needed spacers replaced to prevent rubbing/chaffing
and other stuff.
x 1988
Well it is that time again
One washed and off to bed
and another awoken from its summer slumber (7-8 months) but started on the button. (well screwdriver as I had to drill the lock out having lost my keys !)
x 8322
Excellent! Just as I find with my Saxo... It can stand for months and then start instantly... Even without a battery top-up...
These little Cits really are rather excellent little cars...
Nite, nite Activa - sleep well and watch the tinworms don't bite!
x 6955
Looking fantastic Alasdair.
Fake Concern
x 65
Unread post by Fake Concern »
I don't even know which of your cars I like the most now!
Now you need a C4 VTS 180!
x 1988
Nor do I, but I use Man-Logic to reason why I have 4 runners.
I will guess at:
ACTIVA
AX
C5x7
CX
Still want an H-Van on a Land-Rover chassis :)
x 8322
Stickyfinger wrote: 03 Nov 2018, 07:53 Still want an H-Van on a Land-Rover chassis :)
Almost as desirable as an H Van with an ES9 V6 engine and Activa suspension :wink: :-D
x 1988
Jim, that would just be a bad Activa :)
x 8322
Stickyfinger wrote: 03 Nov 2018, 11:52 Jim, that would just be a bad Activa :)
OK, Good point well made! delete the Activa bits but leave it suspended on green balls ;)
x 1988
But then no 4x4 drive and it would neither Citroen or LandRover owners :)
x 8322
I believe there's been a Land Rover or two converted to Citroen suspension Alasdair... Do I understand that in doing so renders them 2WD only?
x 3566
If you're after a bit of inspiration as to what can be achieved with grafting one vehicle into another, then I can thoroughly recommend 'Project Binky'. A mildly challenging concoction of putting a 4WD Toyota Celica 2.0 litre engine, gearbox and drivetrain into an old Mini. The videos are stupidly funny, but it does actually show you what can be achieved if you really don't want to be defeated by anything. They have an engineering solution for absolutely everything :lol: They've been at it for 4 years now and have only just got to the stage of putting in the wiring harness ! Thoroughly recommended viewing... if you've got a day or so spare to watch all the episodes :)
x 8322
bobins wrote: 03 Nov 2018, 19:48 If you're after a bit of inspiration as to what can be achieved with grafting one vehicle into another, then I can thoroughly recommend 'Project Binky'. A mildly challenging concoction of putting a 4WD Toyota Celica 2.0 litre engine, gearbox and drivetrain into an old Mini.
That is wonderfully bonkers!!!! Love it 8-)
x 1988
High flow return 5-way leaking.....oil on drive....gerrrrrrrrrr
Looking in through the left side wheel arch.
Leak at 2 on the "ribbed Moulded pipe"
Pipe cut and a small section inserted...and leaking at 1
