08 c5 clutch change
kennatt
08 c5 clutch change
Hi all I am about to change the clutch (Full kit bearing pressure ,friction and dmf) I have read that it is also essential to replace the fork and pivot pin,but a well known X citroen garage mechanic ,now independent ,says not essential, any one know the true recommendation ,don't want to have to pull box a second time, I have the clutch kit but no pivot or forks included ,the suppliers says they don,t get asked for them . Thank in anticipation of some knowledgeable person replying.
- x 6963
Re: 08 c5 clutch change
Hi and welcome.
The official recommendation is to always replace the clutch bearing when replacing the clutch mechanism or the clutch disc - that is as written in the service documentation. There is no specific mention of the fork or pivot pin.
Also, another recommendation - in order to improve the centring of the friction plate and to eliminate engine jerks, vibrations and noise, compress the clutch mechanism when tightening the fixing bolts.
Simple76
- x 9
No need to replace fork or pivot pin . However would change gearbox drive shaft seals when gearbox out.
kennatt
Ok done the clutch full kit,no major problems,but whilst under car found that at some time (Only had car for 6 months) a dodgy type of repair has been carried out to the pipe that runs along the front of the car and up the nearside,I think its the power steering return ,Its been done to the aluminum pipe near the subframe, obviously been broken at some stage ,think I read on here somewhere that its a common failure caused by chaffing of the pipe inside a clip ,A short piece of rubber pipe has been hoses clipped over the break ,There is a very slight weep from this joint. So a couple of questions.
Is this pipe the low pressure return from rack.
what pressure is it carrying
and is this type of repair acceptable don't like the look of it myself
any one repaired this pipe
Was wondering if suitable size compression type fitting would be better
Any idea as to the price of a new pipe
- x 3567
Whilst I can't answer your pressure related questions, it's worth bearing in mind that there is a - rubber pipe over aluminium pipe clipped with a hose clip - as standard on these power steering return pipes. I've got a spare pipe at home so can put up a picture of what it's supposed to look like when I get back later today.
IIRC, there was a recall or modification to be carried out where the pipe was secured to the chassis / subframe, but I think it's on the offside (though I could easily be wrong on that - perhaps Marc (GMAB) could check?)
For context - in MOT terms, a small leak is acceptable whereas a leak that leaves a puddle within a few minutes would be a fail.
