Brake pipe nut sizes
EDC5
x 130
Re: Brake pipe nut sizes
Unread post by EDC5 »
I'm after a ser myself as they look like really useful things. How about this set?: https://www.ebay.co.uk/itm/OPEN-FLARE-N ... SwpINZX6h1
I know for a fact that I'll need new brake bleeding nipples for my rear callipers next time I bleed them as I nearly rounded them off tightening them up last time with a normal spanner! In hindsight I should have used a socket at least.
oscar
x 8
Unread post by oscar »
And to think all i wanted to Know what size spanner to get! so know about as much as i started with? :!: #-o [-o< [-o< [-o<
x 1939
At least you know what you don't know now.
x 1746
"How about this set?..." ???
They look fine, and a good price.
oscar
x 8
I got the set above a bit cheaper than that set!
the other thing i need to know is those clips(i presume clips)that are around ends of flexible are they part of body/arm or do they move/unclip etc out of the way?
sparksie
x 33
Unread post by sparksie »
OK something weird happened.
I posted a reply to this, yesterday, but it hasn't appeared.
Short answer to the original question is the nuts will most likely be M10 fine thread and require a 10mm, or 11mm spanner, which should be a "flare nut", or "brake pipe" spanner, not a normal open end.
No idea why my original reply didn't work...
Sparksie
2000 Xantia 1.9TurboD
x 1746
...easy enough to forget to hit Submit. Have done it myself.
