Berlingo first gear
Raul
Berlingo first gear
Unread post by Raul »
Hello
I just bought a berlingo 2.0 hdi . When I made a test drive I unfortunately did not notice that the first gear does not want to go in very smoothly. Is it a sign of bad synhros? Other gears go in nicely.
Citroen gsa 1299 , 1982
Citroen gs 1,2 pallas 1977
Citroen xantia 1,9 td estate 1996
Citroen Xantia 2.0 hdi 90 2000
x 1464
Re: Berlingo first gear
Unread post by xantia_v6 »
Does it go in smoothly if the engine is stopped? It is usually a sign that the clutch is not disengaging fully.
Raul
xantia_v6 wrote: 10 Sep 2018, 10:27 Does it go in smoothly if the engine is stopped? It is usually a sign that the clutch is not disengaging fully.
When the engine is stopped it goes in not super smoothly but I would say normally. The trouble is when stopping at the intersection sometimes it does not want to go in and I have to release the clutch and try again or select some other gear before going to first gear. Also with low speed from selecting from 2 to 1 makes a crunch so I try to drive this way that I select to first gear only when the car is almost standing.
x 1746
As well as the clutch, check also what oil is in the 'box. Should be a GL-4 (not 5 or 4/5) spec: Total Transmission 8 gear oil, 75W-80 GL-4. This allows the synchromesh (gear engagement and changes) to operate at its best.
flying clutchman
x 3
Unread post by flying clutchman »
When you are stopped and the engine is running, will it go in to gear ok? Also is reverse ok?
Raul
flying clutchman wrote: 10 Sep 2018, 18:33 When you are stopped and the engine is running, will it go in to gear ok? Also is reverse ok?
Sometimes it goes in nicely but sometimes it does not go in at all. Overall it is not very bad, I can drive the car nicely but I am afraid that my wife could be in trouble when waiting for the green light and then the gear does not switch in. Reverse seems to go in nicely.
Is there anything I can do to adjust the clutch? I read that berlingos have automatically adjusted clutch cable.
I will change the gearbox oil.
