Clio 197 rear discs
This is the Forum for all your Renault Technical Questions, Problems or Advice.
beemaa
Clio 197 rear discs
Unread post by beemaa »
Hi All,
I just got told I need new discs for my 197 on the rear.
I'm not sure what the options are as the mechanic said they come pre assembled with built in bearing kits?
I'm not sure how accurate this is as I have seen some online that come with / without the bearing as well as some others that come with abs bearing.
If anyone can point me in the right direct in terms of what I should be sourcing (I said I would buy it as he wants some mega money for the discs).
Thx
Pedro :-D
x 1476
Re: Clio 197 rear discs
Unread post by xantia_v6 »
I am no expert on Clios, but PSA cars of the same era used both types of rear bearings (those with disks attached and those without), and you have to go with the sort that were originally fitted (and the disks with bearings are rather expensive). It may be feasible to have your old disks re-machined and still be within spec, as a cheaper option.
beemaa
Thanks Xantia.
moizeau
x 423
Unread post by moizeau »
Why were told you needed new disks? Thickness, a bit of a lip on the exterior or braking?
Pete
