blower heater xsara Picasso 2006
wazzy
Unread post by wazzy »
Blower not working so checked fuse was ok tested blower heater was working but not in car could it be ignition barrel any help welcome and pis if possible. ](*,) ](*,) ]
x 6956
Re: blower heater xsara Picasso 2006
Can you be a little clearer?
  • Is the blower working on ANY speed in the car?
  • How can the Blower Heater be working if the Blower Motor isn't working?
  • If the Blower motor is working when connected independently to a separate power supply, then internal wiring is a cause.
Does the blower start working if you gently wiggle the keys in the ignition? If so, have a look at this video:
wazzy
Ok thanks got new ignition wiring so i will try it thanks
