Electrican help please? Citroen C4GP ABS wiring mare (fixed)
x 5674
Re: Electrican help please? Citroen C4GP ABS wiring mare (fixed)
It will sit in the outbox until Marc reads it, then will move to the Sent box.
x 1942
If a PM is in the Outbox it simply means that it hasn't been read by the recipient yet. Marc probably has other things to do today and hasn't had time to look in here yet.
x 6957
Hi Ian - on the Forum system, private messages sit in the outbox until the recipient has actually read them - it works slightly differently on the Forum that an email program. Anyway, here is the complete ESP system wiring Diagram for you. I have included the wiring descriptions for the main plugs below. I can't help with the colours of the wires, because in this case most of them are coded 'ND' non-defined - so could be anything. So focus on the pins.
If you need any more wiring codes for the others coming out of the ESP ECU, then just list them and I'll get back to you.
@ Steve / Paul - Yes - a new house kitten we have 'inherited and it got stuck behind a large unit - so guess what I have been doing since 03:30AM..... :-D
CodeDescription
HardwareN/A
7825Rear RH ESP Sensor
7820Rear LH ESP Sensor
7815Front RH ESP Sensor
7810Front LH ESP Sensor
1611Clutch Release Pedal Angle Position Sensor
7800Esp Ecu
4410Brake Fluid Level Switch
7804ESP Accelerometer Gyroscope
7095Electric Handbrake Assembly /
2120Brake Twin Function Switch /
WiresN/A
7032URight-Hand Rear Wheel Speed Signal Reference
7031URight-Hand Rear Wheel Speed Signal
7022ULeft-Hand Rear Wheel Speed Signal Reference
7021ULeft-Hand Rear Wheel Speed Signal
7012URight-Hand Front Wheel Speed Signal Reference
7011URight-Hand Front Wheel Speed Signal
7002ULeft-Hand Front Wheel Speed Signal Reference
7001ULeft-Hand Front Wheel Speed Signal
Nemesis84
Unread post by Nemesis84 »
Hi Marc / All - I needed to crack on and see what I could find continuity bit by bit...
So! Update: I managed to trace the continuity fault to the actual connector to the abs ecu - once I'd finally worked out it was possible to take the grey plastic mount off the bulk wire connector (/break in) and see the individual wire termination I found there was a break in the cable (completely corroded and green!) about 5cm from its final termination (so hidden in the connector head)! Patched a new wire to bridge the corroded gap and it's sorted it :)
If anyone was interested the yellow of the pair terminated one row up and slightly to the left from the arrowed pin on my previous image. which \following Marcs diagram, and spotting there was a tiny tiny number printed on the physical head the wiring diagram indeed matches up to the pin positon :)
Thanks for your help Marc - much appreciated!
x 6957
No worries, another result, excellent work - it just goes to show how hidden some of these breakages can be. :-D
pauljordanie
Unread post by pauljordanie »
Im trying to find a pin out diagram of the ABS ECU socket. Which is pin 1, pin 2 etc... Can anyone help please?
pauljordanie
I'm trying to locate a pin out diagram for a 2009 C4GP ECU plug. Which is pin 1, pin 2, etc....
x 6957
In both cases I'll need a VIN to help you as diagrams are dependent upon options and specs.
x 6957
pauljordanie wrote: 14 Nov 2018, 14:01 I'm trying to locate a pin out diagram for a 2009 C4GP ECU plug. Which is pin 1, pin 2, etc....
You'll need to put the VIN HERE. The system software masks the VIN from public view so it's fine to put it here - only staff can see it, but I cannot see it in a Private Message.
pauljordanie
Ok VIN is VF7**************[VIN obfuscated, can be read by forum staff]. I'm also looking for the ABS plug pin numbering as well. Thanks.
x 6957
Ok, here's the ESP / ABS ECU Diagram.
If you need some codes / wires identified let me know.
pauljordanie
Thats great !! Thanks. Do you have the pin numbers for the plug that goes on the ABS ECU. Which is pin 1, pin 2 etc on the socket? I have the socket off the back of the unit. I look at the plug that I pulled off but I dont know which is which pin.
x 6957
The 32 Pin black socket shown at the top of the ESP ECU 7800:
CodePinDescription
194110Alternator Starter ECU Sensor Earth
191212Clutch Pedal Status Info
19159+5 Volts Alternator-Starter Management ECU Sensor
9010Z27High Intersystem 2 Can Bus
9011Z15Low Intersystem 2 Can Bus
442U8Brake Fluid Level Info
BF03U1To Maxi Fuse 2 (Engine Fuse Box)
BF04U25To Maxi Fuse 1 (Engine Fuse Box)
ME10A38Electronic Earth
7842U35Remote Control Wake-Up Information
7112A32Angle Sensor + 12 V Power Supply
9000U26High Intersystem / Can Bus
9001U14Low Intersystem / Can Bus
210U30Stoplamps Control
MC10R13Earth
pauljordanie
Ok, but which pin is pin 1 on the plug? In the picture do I have my probe in pin 3 for example?
x 6957
The numbers should be on the plug - but I can't see much from that picture - it's too dark and not very clear.
