1.6 Hdi / DV4 / DV6 turbo feed modification.
bxzx16v
x 34
Re: 1.6 Hdi / DV4 / DV6 turbo feed modification.
Unread post by bxzx16v »
My Mk3 berlingo 1.6hdi 75bhp has just ticked over to 110k with no major issues in the service history other than servicing, this is a 2009(59) model. Only real problem is a very annoying rattly airbox feed pipe which is soon to be sorted. The mechanic who services it works for Peugeot and says they haven't had any trouble if their serviced regularly.
Mark
SwissSPEC
Unread post by SwissSPEC »
PhilGreaves wrote:Don't the new minis use it now? has anyone looked at these?
Depends what age the mini is, if its a 2011 model or later then its got the better BMW 1.6 unit fitted rather than the PSA unit which i believe you're referring to, so no point in having a look at mine :wink:
CX GTI 2 Turbo (LHD) - Sorn
Bx Gti 16v
BX TZD Turbo - Sorn
C5 Mk1 LX 2.0HDi Estate
Mini Cooper D Clubman
daviemck2006
x 485
Unread post by daviemck2006 »
Our Mini which I hated and called a Bini and was towed back to the dealer 3 times before it was 2 years old, was a 60 plate 1.6 diesel which had the psa engine. It was 6 months old when we bought it, it was the dealer demo and the dealer told us their new demo had an updated engine, which probably meant the BMW one.
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
aneesh84
x 29
Unread post by aneesh84 »
Lighty wrote: 14 Dec 2013, 07:01 The exhaust filter, or DPF needs to be removed to get the oil feed pipe off, the filter is located inside the lower banjo bolt.
Removing the dpf is quite a big job, especially on your 1st attempt, but there is nothing impossible, it's just nuts & bolts.
We remove the radiator on most cars for easier access.
I would strongly recommend removing the filter on ALL 1.6 hdi engines. We have had some well looked after vehicles with turbo failure, so don't think yours will be ok.
Would you recommend the same for 2.0 HDI 16V 138 RHR engine?
C5 2005 2.0 HDI 138
Nissan Leaf 2018 40Kwh
EDC5
x 130
Unread post by EDC5 »
aneesh84 wrote: 24 May 2018, 00:42
I assume you haven't found where the turbo is hidden on the RHR engine :rofl2:
I think access to the turbo is really difficult so I wouldn't bother. As long as regular oil changes are used to keep the crud out of the oil then it should be ok.
aneesh84
x 29
EDC5 wrote: 24 May 2018, 10:26
Thanks for the assurance. I change my oil every year. I use 5W40 since my RHR engine does not have DPF. Should be okay?
Also any recommendations if I should be blanking my EGR using a plate? No issues till now, and have owned this car since 2 years. But was just trying to make sure I do everything to make it last long.
C5 2005 2.0 HDI 138
EDC5
x 130
aneesh84 wrote: 24 May 2018, 14:31
No DPF on an RHR? Very lucky :-D . So yeah I suppose you don't need the special Total oil that I have to use.
Truth be told the EGR fouls up the inlet quite badly, I’ve removed my air doser just to see into the manifold and it was caked in tar-like filth. Not sure what I'm going to do about it really, I suppose I'd have to remove the inlet manifold to clean it properly.
Not sure if blanking your EGR is legal in Portugal but it isn't here so I won’t say anything on the matter :oops:
aneesh84
x 29
EDC5 wrote: 24 May 2018, 14:42
Yeah its a March 2005 model, probably the Euro 3 stock before it went to Euro 4.
My 1999 2.0 HDI Xantia 110 , has never given me any problems despite having an EGR. Did they mess up something on the RHR that I hear more complaints about the EGR?
Legality is really not much of an issue here! :-) So whatever is best for the car is what matters. The MOT equivalent never do such detailed checks, and nor do the insurance care about it.
C5 2005 2.0 HDI 138
EDC5
x 130
I'm not sure if they messed up with the RHR but I remember a few years ago my dad had two Peugeot 306 1.9 diesels, one newer than the other. The intake manifold for the newer one with EGR was disgusting, again, covered in a tar like substance. The other one meanwhile was spotless. I think EGR can be done well but there again it can be done poorly too.
aneesh84 wrote: 24 May 2018, 14:53 Legality is really not much of an issue here! :-) So whatever is best for the car is what matters. The MOT equivalent never do such detailed checks, and nor do the insurance care about it.
Sounds perfect :-D , Next you’ll be telling me that Portugal has sunny weather and not constant rain :rofl2:
aneesh84
x 29
EDC5 wrote: 24 May 2018, 15:08 Sounds perfect :-D , Next you’ll be telling me that Portugal has sunny weather and not constant rain :rofl2:
That's also mostly true! :-)
Nice weather makes it much more fun to spend the weekends doing stuff on the car!
C5 2005 2.0 HDI 138
Axa
Unread post by Axa »
Is there anyone that know for sure if the oil contamination causing the sot mix clogging the intake manifold and valves are caused by crancase ventilation not being efficient enough in avoiding oil vapour reaching into the intake manifold? Or can it also be as I've read some about, the DPG causing so much back pressure in the turbo so oil are pushed trough the turbo bearing and into the intake manifold?
2006 C5 1.6 HDi ( vin: VF7**************[VIN obfuscated, can be read by forum staff] )
2008 Grand Espace 2.0Dci Auto
cancunia
Unread post by cancunia »
Some good info in here. I've seen more sources that I'd happily trust say to take the gauze filter out than I have seen saying to leave it in. I have my new (to me) 2008 1.6 in bits at the moment while doing the cam belt so I've taken off the exhaust & the oil feed pipe behind. There's no blockage visible in the gauze filter but I think based on the wisdom in this thread that I will remove the filter before putting the oil feed pipe back on. Having read a lot on the subject, I still can't see any good reason for having the filter there in the first place.
Pappi
Unread post by Pappi »
Hi guys. Bumping this thread. I've just baught a 407 1,6HDI with only 88000 miles on it. I got it really, really cheap.
I want to remove the wire mesh filter on it. Do you know if there is a step by step instruction or video anywhere?
The car runs fine and I do not have any lack of power, but in my opinion the turbo has a slightly too loud whining noise. So I'll change the oil and remove the wire mesh filter. But I'll need guidance from a guide or something to do it...
cancunia
At the risk of being banned for daring to post a link to another forum.....
https://www.berlingoforum.com/thread-17377.html
x 5678
Not a problem - we don't exist in a vacuum :)
