lexia install not working on win xp 32
crispinchurch
Unread post by crispinchurch »
win xp with service pack 3 .net frame work 4
cd got many folders lexia 45 i started with the icon instlex3 was a plain window box not the icon in icon folder there was a instructions folder with 6 .bmp icons windows .bmp file not reconised
when click on a black dos box flashes up and thats it will not go any further
x 6956
Re: lexia install not working on win xp 32
You'll need to locate the installable .EXE file. Files with a .BMP extension are just bit-mapped graphics files.
crispinchurch
yes clicked on instlx3.exe
and install.exe
the seller sent me a download link and even that did not work
any one got dvd i could down load ?
x 6956
I think the majority of us here with Diagnostics now use Diabox, and I just noticed that if this is for your C4 GP it will likely need Diagbox anyway. In case you didn't know Diagbox also contains the encapsulated Lexia and PP2000 software and will launch whichever version is required for the vehicle being tested.
crispinchurch
oh thats great
can i just install diagbox ?
x 6956
Make sure you are using a 32 bit Operating System (Win 7 is fine). This will be required should you need to use the encapsulated Lexia or Peugeot Planet 2000 on another vehicle as these particular apps are written using 16 Bit code and will not run on any 64 Bit OS unless using a virtual machine (VM). I personally do not recommend VMs at all for diagnostics sue to the other communication errors and problems that can arise.
As I don't know what version your VCI is, I would install Diagbox V7.02 to start with and then see if you can communicate with the vehicle. Some older units don't have all the hardware components and may have issues talking to some newer vehicles. No 2 are the same it seems!
I always recommend using a separate laptop for diagnostics that is kept with only the basics on - no other unnecessary software or bloatware. Get the latest windows updates and then turn off the windows update service as that can be VERY resource intensive when doing a diagnostic session and can slow things down incredibly.
Follow the installation instructions fully and ensure you don't have any anti virus programmes running and disconnect from the Internet (but leave your wireless or network card enabled).
crispinchurch
hi thanks
the instuction are six .bmp files that can not be read
theres no diagbox only updates there is iso file but looking at that is only the first dvd that would not load
my laptop is win xp 32 bit new install so only have .net framework 4 sp3
tried looking for downloads of diagbox and ones i tired have get blocked even before i download
do you know any really working downloads ?
x 6956
I will send you a Private message shortly regarding this.
crispinchurch
update
got up to diagbox 7.57 installed and working on the dvd i got next few up dates is a french and thats when i start getting errors i have had to fresh install win xp and start over again 3 times i treid to see if a newer udate would make good but no
one question do i have to have laptop connected to internet at time of using ?
x 3306
It is not a good idea to be connected to the Internet while running a Lexia session, in case it tries to update/register the software and gets shut down. I will make sure the WiFi is turned off on my netbook whenever I am planning on connecting it to my C5.
x 6956
crispinchurch wrote: 13 Jul 2018, 19:44 update
I would not go past this update - it should have everything you need and is the stable version.
Also do not mix updates from different authors - they sometimes need to be applied in sequence from the same author or you will corrupt the data files.
brad306
Unread post by brad306 »
Hey crispinchurch,
how did you manage to install the program? I currently have the same problem. Already tried it on win XP emulation and on original win xp.
Only the control panel pops up for a micro second.
x 6956
You'll need to explain a little more clearly what your problem is.
brad306
The Problem is that the Instlex3.exe in the Lexia 45 folder has the wrong sign (win command box instead of CD with Citroën sign). If I double click the command box pops up and closes without a message.
Thats all what happens.
brad306
Please I need some help. I'm unable to Open instlex3.exe.
