There's no pump as such in the tank on the XUD models at least, just the pickup and sender unit. The gauze can be cleaned as Jim says, rather than replaced.
Going to look up this Marine 16 stuff, I'd guess it's some sort of anti-bacterial additive used in boat tanks (where, as I mentioned, this stuff is/was more prevalent.) Could be useful.
And so it goes on! Intermittent power loss and stalling
ekjdm14
- x 262
Re: And so it goes on! Intermittent power loss and stalling
'96 ZX SX 1.9TD, White, 88k
'12 Mini freebie project
Rhothgar
- (Donor 2026)
- x 221
Have a read of that article someone linked to this oost from memory.
It's a cleaner they use in canal boats. Rates highly in killing the bacteria.
Rhothgar
- (Donor 2026)
- x 221
ekjdm14 wrote: 15 Apr 2018, 17:48 There's no pump as such in the tank on the XUD models at least, just the pickup and sender unit. The gauze can be cleaned as Jim says, rather than replaced.
No, of course! The pump's on the engine!!!
Was it yourself that kindly linked the article? A worthwhile read.
ekjdm14
- x 262
It weren't me guv'nor, not as I remember anyway. Brain is pretty much scattered at the moment though lol
Rhothgar
- (Donor 2026)
- x 221
ekjdm14 wrote: 16 Apr 2018, 14:56 It weren't me guv'nor, not as I remember anyway. Brain is pretty much scattered at the moment though lol
I'm familiar with that feeling.
- x 8407
Same here
harryp
- x 73
I have encountered the microbes in a previous life when I owned a small yacht! I sailed from Crinan to Plymouth as navigator on a friends yacht and the fuel tank was thick with the stuff. I forms at the diesel water interface in the fuel tank. Remember it well as we had to keep stopping and cleaning out the pump as it clogged up. This was in a F8 gale and not at all amusing, even in a 42 footer. Apparently the cure is to clean the tank and refill but with a biocide additive, the name of which Ii cannot remember; if I can find out will post. Yes it is b....dy awful stuff, but the additive does a good job. Meths does absorb the water, but you atill need to make sure your tank is water free on refill.
Good luch
Good luch
Regards, Harry
2000 Nov Forte HDI 110 hatch in Wicked Red; currently SORN
2000 Mar Exclusive HDI hatch in Quartz; currently SORN
2013 C4 Picasso Excl E
Peugeot 207cc 1.6 Roland Garros
