Eolys?
Xantippa
- x 29
Re: Eolys?
I checked that connector is green so 176 is the right fluid?
cachaciero
- x 9
Re: Eolys?
Marc I was offering that " nugget " of info more for urzica who has a 2ltr.which I assumed by the date is a mk2. In fact the advice is superfluous for a 2ltr as these were all 176 straight from the factory. The only model where confusion can and does reign is the 2.2 2001-2006 which could have either and my comment would apply to this model. DPX42 was phased out during the production of the mk1 and only applied to the 2.2 anyway until the introduction of the "face lifted " 2.0 ltr.
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
- x 6948
Re: Eolys?
Unless he's changed it, Xantippa has a 2009 C5 X7 3.0 L 240 RPO: 12001, but this table should make it easier to understand. However, I always recommend visually checking the click fit union, the RPO and finally with the dealer to be 100% sure. Especially on the changeover from Green to Blue.
So here is a guide I've put together:
So only the GREEN fluid types can be mixed when topping up - you must never mix the DPX42 or the EOLYS Poweflex with any other additive fluid.
Click Fit Connector
| Click Fit Colour | RPO | Date | EOLYS |
| White | To 9492 | To 04/11/2002 | EOLYS DPX42 |
| GREEN | 9493 to 12109 | 05/11/2002 to 03/01/2010 | EOLYS 176 |
| GREEN | 12110 to 12165 | 04/01/2010 to 28/02/2010 | Infineum F7995 |
| BLUE | 12166 on | 01/03/2010 on | EOLYS Powerflex |
Click Fit Connector
| Green Click Fit | Blue Click Fit |
Xantippa
- x 29
Re: Eolys?
Thanks for that pic Marc! I was wondering if it's normal that there's only one hose/connector on mine, but it seems normal with Green Click Fit.
BTW, is this info about correct eolys version for my car available somewhere on service.citroen.com?
- x 6948
Re: Eolys?
It's chargeable - not freely available - I have simplified the explanation from other sources as even in the service docs they do not provide the RPO dates and they do not specify the correct one on a per car basis - so you need to check colour of click fit and RPO and if you still want peace of mind, with the dealer - so I've done it for you
- x 6948
Re: Eolys?
Here's a 3l kit for your car
https://www.ebay.com/itm/WALKER-80618-E ... 2665939759
Xantippa
- x 29
Re: Eolys?
GiveMeABreak wrote: 03 Apr 2018, 17:35 Here's a 3l kit for your car
I ordered this, it was cheaper: https://www.ebay.com/itm/Walker-Eolys-1 ... 2749.l2649
- x 6948
Re: Eolys?
Ok, I'll give you that one - as I've done all the other work for you....
Xantippa
- x 29
Re: Eolys?
OK, just topped up fluid. It wasn´t a walk in the park because additive came with straight connector in the end of hose, and there is very small place for that connector (car´s own connector is angled). I managed however to fill fluid (all 3l went in, no overflow). Then I tried to reset fluid with diagbox without success. Went to maintenance and additive menu, went through that many times and cleared faults, but additive low fault in bsi comes back again. Was there a good how to for resetting eolys level somewhere?
- x 1497
Xantippa
- x 29
Re: Eolys?
No, I think not. I went via maintenance and diesel additive and so on... Diagbox asked about kilometers at the moment, service interval, engine size, gearbox. Last step stated that I should also top up the container (which I did). Couldn't get rid off that fault code, it just pops up right back after erasing.
- x 6948
Re: Eolys?
You’re not in the right place then. Do your global test first, then go into the injection ECU then you should see a list of menus. Look down there for the additive one and choose the top up or refill additive (or similar) option, then follow guide.
Xantippa
- x 29
Re: Eolys?
That did the trick, thank you! Diagbox menu structure is always mystery to me. Maybe I should use it more...
BTW, went to local garage to try this out before doing it myself, and even they couldn't do it. They had Autocom and some other general diagnosis tool that has worked at least with other C5 X7's.
- x 6948
Re: Eolys?
Excellent - I should of asked you to record the menu options down and the process for others - so we could refer to it - as it is slightly different for each model and depending on the DB version too
Xantippa
- x 29
Re: Eolys?
Never ever read user manuals or make documentation on what you do!
