Anyway, back on topic! What a great article that is.
Thanks for sharing.
Does anyone have any experience of any of the products tested in the article?
And so it goes on! Intermittent power loss and stalling
Rhothgar
- (Donor 2026)
- x 221
- x 8411
Re: And so it goes on! Intermittent power loss and stalling
Just shows how bloody bizarre computer systems are
I find it amazing anything remotely alive could live happily in diesel (or at the diesel/water interface) but there you go... Seems life can live just about anywhere given half a chance...
Onlinemyglaren
- x 5672
CitroJim wrote: 09 Apr 2018, 07:42 Just shows how bloody bizarre computer systems are
Have you seen this Jim?
https://oceantoday.noaa.gov/underwaterv ... ermal flow
And
Little buggers are everywhere.
Sorry about the accents.
- x 8411
As soon as my feeble brain allows me to I will Steve... Videos are beyond me at present
- x 1490
When I was at Uni, I grew some bacteria that lived in acid media - we started at pH1, and they produced acid species as they grew, so the pH went down - ended up being -1 or some such. Thiobacillus ferrooxidans... I shall never forget that. If you're really bored, I wrote a paper on it.... Complex stuff from a past life!
ekjdm14
- x 263
Agree there's not much chance of getting shot of diesel bug with a dose of unleaded, it's even been found in 2-stroke premix tanks living off the oily goodness in there. (and in that case did a number on the fuel pump & carb, their acidic excreta had eaten away the alloy to a sludge).
I fear White may have an infestation, although to a lesser degree & I cleaned the sender/pickup a few months back, but will check again soon. I think the best solution is probably to use the car more often, heating up the fuel in the tank via return flow & making it uncomfortably hot for the little blighters!
'96 ZX SX 1.9TD, White, 88k
'12 Mini freebie project
Onlinemyglaren
- x 5672
I wonder if meths would work?
I used to add it to the Imp tank, which was prone to condensation. Not a clue on how it would work with diesel but should mix with the water and remove it and should also kill bacteria.
crapday69
- (Donor 2017)
- x 59
Ill give Walter White a call see if he has any left
ekjdm14
- x 263
That's an interesting idea, could be worth a try although the ethanol in modern fuels would surely have done the same thing if it were effective? Maybe a higher concentration of meths would work.
Onlinemyglaren
- x 5672
Is ethanol added to diesel though - I was under the impression it was only added to petrol in the UK.
- x 8411
myglaren wrote: 11 Apr 2018, 17:09 Is ethanol added to diesel though - I was under the impression it was only added to petrol in the UK.
Not as far as I know... I believe all diesel now has a certain percentage of bio in it though... I wonder if that encourages the wildlife to grow?
ekjdm14
- x 263
Ah of course, not sure if diesel has ethanol after all. But then again if it doesn't (and seeing what the stuff does to hoses/seals etc on petrol vehicles) would you really want to put it though the diesel fuel system?
The bio being a factor in it's growth could well be on the right track, I mean it's not exactly been commonplace in the past for cars to suffer (more of a marine/boat problem from what I'd read on it). I thought it was just unlucky that White had some gunge but if a few cars start turning up with the stuff maybe it is on the increase now...
Onlinemyglaren
- x 5672
ekjdm14 wrote: 11 Apr 2018, 17:59 Ah of course, not sure if diesel has ethanol after all. But then again if it doesn't (and seeing what the stuff does to hoses/seals etc on petrol vehicles) would you really want to put it though the diesel fuel system?
An old article but may have some truth to it.
https://www.telegraph.co.uk/news/uknews ... iesel.html
Rhothgar
- (Donor 2026)
- x 221
It is the bio element that carries more bacteria.
I am going to Marine 16 a go to eradicate the cATP's.
Not sure if anyone has answered this but can the filter in the tank be changed without changing the whole pump?
- x 8411
Rhothgar wrote: 14 Apr 2018, 23:31 Not sure if anyone has answered this but can the filter in the tank be changed without changing the whole pump?
It does not need to be replaced Roger, it can be cleaned...
What's Marine 16 and cATPs?
