SMEG Coding Subwoofer
This section is for General Enquiries or for Systems not Covered Above
Moderator: GiveMeABreak
Post Reply
myneur
My Cars: Citroen C5
Post by myneur »
Hi guys. Does anyone know how to code C5 SMEG unit with standard speakers to work with original hifi with subwoofer?
I could replace RNEG in 2012 C5 to SMEG, but the only part of the configuration we don't know how to do is to enable the subwoofer. Thank you a lot!
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow
x 5708
Re: SMEG Coding Subwoofer
Post by GiveMeABreak »
When you say original HiFi - I assume you are talking about the optional Philips HiFI with the subwoofer in the boot?
The official HiFi option has a separate ECU (8424) that may need configuring and also the BSI itself has a setting that need to be set- 'Presence of an audio equaliser amplifier' to 'present'.
As for the SMEG configuration, depending on the version, some can't be telecoded using Diagbox offline, they may need a live PSA server download to configure them - this will depend on the version though.
myneur
My Cars: Citroen C5
Post by myneur »
Yes, now I have an original RNEG hifi with a subwoofer in a boot. I'd like to replace it with a SMEG unit version 6.1 R20, that is configured for a standard hifi without subwoofer, so I'd need to enable it.
Anything else necessary for the version 6.1 R20? Is the PSA server download necessary for this version?
Thank you a lot for this knowledge!
myneur
My Cars: Citroen C5
Post by myneur »
... my VIN is VF7**************[VIN obfuscated, can be read by forum staff] if it helps.
C15 Romahome White
CX 20 Polar White
x 5708
6.1 R20 is the actual firmware version, not the SMEG unit version. SMEG IV2 is the one that needs server coding IIRC.
myneur
My Cars: Citroen C5
Post by myneur »
Thank you man! Is there any guidance, how to server code it?
C15 Romahome White
CX 20 Polar White
x 5708
It is very tricky, because the problem you have is this:
You cannot telecode the SMEG IV2 unit as I understand it, because it will not appear in the BSI. So to get it into the BSI, the dealer has to download the software to the BSI and this may require another vehicles VIN if your car did not have the original equipment. Not many dealers will do this.
Only when it is programmed into the BSI can the SMEG unit be coded, but again I’m not sure if you can do this with a Diagbox or will need to get the dealer to do it, as it needs the PSA server access.
myneur
My Cars: Citroen C5
Post by myneur »
Thank you, that sounds pretty complex, so it is not probably worth the effort:/
MRC5HDI
My Cars: Citroen C5
Post by MRC5HDI »
you need a special reference to works HIFI PHILIPS
C15 Romahome White
CX 20 Polar White
x 5708
Sorry that doesn’t make any sense^ what do you mean - needs a special reference?
myneur
My Cars: Citroen C5
Post by myneur »
He probably means that I have to order a special unit that will work with subwoofer I guess.
C15 Romahome White
CX 20 Polar White
x 5708
If that is the case, you still may have a problem, because the optional CAN system hi-fi amp system needs to be compatible with the X7’s electronic architecture. This SMEG unit that you have may not be compatible with the 2009 model’s CAN2004 electronic architecture. Hard to say really when factoring in the HiFi option to the problem.
MRC5HDI
My Cars: Citroen C5
Post by MRC5HDI »
When you go to citroen to buy a smeg, there are many references. there is a different reference for models with audio amplifier
C15 Romahome White
CX 20 Polar White
x 5708
That makes more sense, :-D
Post Reply
