x 3304
Re: Picture(s) of the day..
Serious streamlining, and the added radome may help with the reduced visibility!
x 8353
Hell Razor5543 wrote: 03 Mar 2018, 11:28 Serious streamlining, and the added radome may help with the reduced visibility!
:rofl2:
It would make a wonderful ski jump I reckon :)
x 8353
An interesting new take on screened audio cables :twisted:
Own Work
Own Work
This is what I found when I chopped up a cheap eBay cable I'd been having some hum and noise problems with :lol:
It must be a new type of screening I've not seen before :roll:
x 3304
I would check the description with a magnifying lens. Last time I found something like this the letters "un" were white on white! :D (Joking).
x 1240
Unread post by Peter.N. »
Conductive plastic? :? :roll:
x 5671
That'll be the magic invisible screening they charge 50% extra for :)
x 8353
^^^ :lol: at all the above three comments :D
At just over a quid each plus free P&P I suppose it was daft to expect quality stuff... The phono plugs are supposedly gold plated... If so it's a shocking waste of gold....
x 1240
I have a reel of twin screened if you want some Jim, but you will have to fit your own plugs, can you remember how to do that? :wink:
x 8353
Peter.N. wrote: 04 Mar 2018, 14:43 But you will have to fit your own plugs, can you remember how to do that? :wink:
:lol: If that comment came from anyone else Peter, they'd have been on the receiving end of a good thump! Remember I'm trained in the martial arts ;) :lol:
I'll have you know that this very morning I've been making up Phono to 5-pin DIN leads [-X
I was hoping to use the lead I showed above to save a couple of phono plugs and a yard or so of twin-screened but after seeing just how rubbish that lead was it went in the bin...
As I say, a terrible waste of gold :(
x 2941
Some of the Renault automatics 18s I think, had screened spark plug leads, when the DIYers replaced them with ordinary leads it made the gearbox go mad, didn't know which gear to be in at any time.
x 8353
Gibbo2286 wrote: 04 Mar 2018, 16:01 Some of the Renault automatics 18s I think, had screened spark plug leads, when the DIYers replaced them with ordinary leads it made the gearbox go mad, didn't know which gear to be in at any time.
I can well believe that. It's amazing how much energy plug leads radiate...
As an illustration, I once blew up an XM Automatic gearbox ECU after laying unscreened test/temporary diagnostic leads across the top of the engine between it and my ELIT...
That worked. I could read and clear the fault codes...
I then started the engine to look at live data... The ELIT survived but the diagnostic bits of the ECU were well and truly wrecked!!! Remarkably, bar that, the ECU still appeared to work...
Those temporary test leads would have been in close proximity and parallel to the rear bank plug leads...
x 1751
That's just awful. For headphone use only - maybe.
How dare anyone attach an RCA plug to such a cable!
x 5671
white exec wrote: 04 Mar 2018, 18:26 That's just awful. For headphone use only - maybe.
It is the typical cheap crap that comes with most stereos. Best chucked away unused.
x 2941
Re: Picture(s) of the day.. Someone's got trouble
This just landed on our football pitch.
x 8353
^^ That looks like a tight fit!
