Hello to all.
We now use our 1.4hdi Xsara Estate for work deliveries in the mornings - hundreds of gearchanges.
A few weeks ago the clutch pedal did not return - no shock to us as we have encountered the same on a 406.
Toe under the pedal - a quick flick and all back to normal.
Same again last week - 3 times in 5 minutes - then perfect.
Same again this Monday - maybe 6 times in the space of 5 minutes.
Presume its the clutch cable at the end of its life - its the one with the built-in ratchet in the cable and not up at the pedal.
Ordered a new cable and put some spacers in the end of the existing cable to give us a few more days of life.
Much worse this morning - maybe 15 times and at the end of the morning - more often than not.
Going to use our Laguna tomorrow (risky at the best of times) and wait for the cable to arrive - but its a holiday here on Friday - 14th July - so probably stuck for an extra few days.
Any other ideas while we wait - hate to think that it was the pressure plate or release bearing as the clutch was done about 6 months before we bought the car. Worrying thing is that there is a distinct difference in noise with the clutch in and out...........................
Strange Xsara Clutch Pedal
xsaras4ever
- x 44
Jumper 2.5d
406 Phase 2 Estate, Hdi
Fiat 500 (2009)
1997 Audi A3 tdi
Peugeot 205 td
Fordson Major Tractor
Nuffield 460 tractor
JCB 3cx
Fordson Super Dexta
Massey Ferguson 65
Fiat 500 (2009)
1997 Audi A3 tdi
Peugeot 205 td
JCB 3cx
Fordson Super Dexta
Massey Ferguson 65
xsaras4ever
- x 44
Re: Strange Xsara Clutch Pedal
New Clutch cable fitted - back to normal operation
Jumper 2.5d
Fiat 500 (2009)
1997 Audi A3 tdi
Peugeot 205 td
JCB 3cx
Fordson Super Dexta
Massey Ferguson 65
Fiat 500 (2009)
1997 Audi A3 tdi
Peugeot 205 td
JCB 3cx
Fordson Super Dexta
Massey Ferguson 65
- x 8412
I was just about to ask if it was cable or hydraulic..
Question answered and good news
xsaras4ever
- x 44
Thanks Jim. Happy days with the clutch.
We deliver newspapers in the morning - starting at 3h30. A good clutch is essential.
We just fixed the gadget that keeps the door open when you fling it open in a hurry - now moving on to the heater blower not working in advance of actually needing it - a first for us.
All the corn has been harvested here so the farmers will start to plough in the next few weeks - this will make it foggy in the early mornings - trivial to most people but important to us.
Jumper 2.5d
Fiat 500 (2009)
1997 Audi A3 tdi
Peugeot 205 td
JCB 3cx
Fordson Super Dexta
Massey Ferguson 65
Fiat 500 (2009)
1997 Audi A3 tdi
Peugeot 205 td
JCB 3cx
Fordson Super Dexta
Massey Ferguson 65
Ricardo
CitroJim wrote: 19 Jul 2017, 09:53 I was just about to ask if it was cable or hydraulic..
Question answered and good news![]()
Good news indeed! I was just going to post a thread with a similar problem.
Lately, I have been getting a strange sensation when pressing the clutch pedal on my 2001 Xsara 1.9D van. As I press down on it, it feels more resistant up to a point, after which it becomes "light" again. It´s as if rolling over a bump/hill; hard and slow, and them easy and loose. I also hear a metalic sound. This happens with the car stopped and engine off.
When moving from a stationary position, as I let the clutch go, I get a big vibration coming through the dashboard.
At the end of the clutch cable there is a metal puck. That is the spacer, right? There is about a centimeter between that and the metal lever that goes into the clutch casing.
Should I replace the cable?
xsaras4ever
- x 44
Hello .
Can't answer your question directly but can make a few observations.
1.) The stiff pressure and then light just sounds like the pressure plate being pressed and then arriving at the max. Nothing odd there.
2.) The vibration ------ we fitted an poor quality clutch kit to our 1.9d zx a few years back. It then vibrated on take-off right away.
We scorched the clutch a bit until it almost smoked - no more vibration. We are not however suggesting this solution.
3.) The metallic sound is worrying - espeially with the car stopped.
A guess would be that it is your release bearing. With the car stationary and the engine turning - does it have a noise when you start to press the clutch ?
Jumper 2.5d
Fiat 500 (2009)
1997 Audi A3 tdi
Peugeot 205 td
JCB 3cx
Fordson Super Dexta
Massey Ferguson 65
Fiat 500 (2009)
1997 Audi A3 tdi
Peugeot 205 td
JCB 3cx
Fordson Super Dexta
Massey Ferguson 65
Ricardo
xsaras4ever wrote: 01 Mar 2018, 10:41 Hello .
2.) I got the car last year, with 133000kms on. The guy I bought it from only had it for about 3 months. He was the second owner. He said to me that he never did any major servicing (belts, clutch, etc...) The clutch seemed normal when I got it. A few months ago, a friend of mine who is a nut about Cits, told me that I would probably have to fit a new spring on the clutch cable. There is one next to the pedal, but it seems fine to me (I am no expert).
3.) Worrying indeed, and I am no expert, as I just mentioned. With the engine running and car stationary, it did not make metallic sound (banging on metal sheet, I would say)
Ricardo
Done! (some time ago.)
The original clutch was gone. Replaced it myself (local mechanic refused to give me an estimate). While at it, replaced a couple of other parts on the suspension and gear linkage.
- x 8412
Ricardo wrote: 26 Oct 2018, 11:04 Done! (some time ago.)
Excellent
Satisfying isn't it
Ricardo
Indeed! Especially after seeing the look on the mechanic´s face after finding out that I done the job we could have done.
- x 8412
- x 1746
