Transponder codeing
Fra21r+
Transponder codeing
Unread post by Fra21r+ »
Hi
Long story but my original key transponder got lost for the original ecu in my van and I do not have the code card as I never received it when I purchased the than
And would like to have the original ecu fitted
Will lexia allow me to code a new transponder chip to the van without the key/immobiliser code
I do have the RPO Number
TIA
Fras
x 3296
Re: Transponder codeing
You can, with proof of vehicle ownership, get the security code from Citroen. They may well charge a fee (around £20).
x 6945
Fra21r+ wrote: 23 Feb 2018, 08:37 Hi
TIA
Fras
In a nutshell no.
You will need the correct confidential code first for the relevant BSI. A fellow member was charged £15 just yesterday for his code, so is variable.
Once you have that, you can code the key, but will need to do all the keys in the same session.
Fra21r+
phoned citroen need to take v5 and two forms of ID and the can supply it straight away for £15.00 plus vat
x 6945
That'll do it. It's not too bad as the dealer gets charged by Citroen too.
Fra21r+
Will lexia be able to code a transponder that is already coded or will I have to purchase blank ones
Anyone of a tutorial for key coding
x 6945
Re: Transponder codeingl
They can’t be coded again to a different BSI and Engine ECU. The key fob(s) / housing you have now were likely to have been from the replacement ECUs from the donor vehicle when it was replaced. If you are going to replace it back with the original BSI, you’ll also need the matching engine ECU and keys, or new blank transponder fobs. The transponders can only be coded once to a BSI, but can be re-paired to the same BSI as needed (if you added a second replacement key for eg), where you then need to reprogram the entire set- but that is not the same as coding a blank key from new. Once a new transponder is initially matched to a BSI and engine ECU, that is it.
Assuming for the year, you’ll be using Lexia software.
Connect up, select vehicle, enter the RPO number of the vehicle as requested.
Go to diagnosis, run a global diagnosis
When it has finished listing all the ECUs, go to the top and select BSI option and enter configuration.
Scroll down the bottom until you see the ‘programming’ option.
Select this and on the next menu, select ‘Key Programming’
Then follow the guided instructions carefully and follow exactly as asked. Some operations are timed, so be prepared and make sure you have everything you need to hand including all the keys to be programmed. Any keys excluded from the session will be cancelled and won’t start the vehicle.
EDC5
x 130
Unread post by EDC5 »
Just to second Marc's comments. It's a simple procedure, I've just done it myself today.
I had a look at this video first just to see what I was up against but it was pleasingly straightforward:
x 6945
Elis has posted a pic of doing this in Diagbox, but I think your Relay is 2002?? IIRC then is will be the Lexia software that is launched for earlier vehicles, so will look different than the screenshot above. But is essentially the same procedure and will be guided once you get into the BSI configuration 👍
Fra21r+
Thanks guys
Yes it 2002 model
Got the code £15 total and received it straight away
Easy diagnostic are out of stock which is a shame as they are only 20 miles away
#-o
Has anyone had success with the ebay one
x 6945
They do sell out quite regularly - but they do get new stock in relatively quickly.
ekjdm14
x 261
Unread post by ekjdm14 »
I've got en eBay one, and seems I got a decent (ish... The 30 pin connector for older cars like Xantia was incorrectly wired but the obd plug worked fine on the 206) one but it's a gamble really. I've seen quite a few struggle and give up so really worth waiting for Easy to restock if you can (especially as they're so close by for any support you need. Plus they'd likely have stock by the time one arrived from China.)
'96 ZX SX 1.9TD, White, 88k
'12 Mini freebie project
Fra21r+
Been a while been using a donor ecu but want to fit the original as its mapped
Transponder lost by cowboy key guy
Bought a vci with laptop from a guys used it a lot with no trouble
Citroen relay 2.2 hdi
2002
Bosch ecu
Marc was good enough to get me the rpo number
(Whitch lexia has never asked for)
New transponder
No remote locking facility
So refit ecu and relevant parts
Reconect battery
Start laptop in lexia select citroen jumper mk2
Enrer vin
Global test
Code unit Yes Yes(highlight)
Select. Next
Ecu code fiat.. validation to continue? Fiat
Verifie
Configuration
Key programming
Must have key.. continue
Entry customer code 5 digit code nubers supplied from citroen
Key code incorect
Enter said code throw acc pedal van starts
Any ideas?
Fra21r+
Ecu code_2 fiat
x 6945
I’m not sure which model you have, (pop your VIN up here if you haven’t elsewhere), but you may have a model with Fiat influences including some ECUs that may need the S1279 module to communicate.
This is true for many of the PSA commercial vehicles as they contain some Ford / Fiat technology.
