I noticed this morning that the central trim has vanished from one of the wheels. It must have fallen out last night on the way home.
It's for a 2003 VTR alloy wheel; I have searched in online auction sites (wheels but not the trim on its own) and on parts sites, but no luck yet. No local breaker to raid either.
Does anyone have any to sell - or know where I can get a suitable replacement? It would be good to hide the wheel nuts!
Thanks.
Jonathan
Mk1 C5 VTR alloy wheel trim required
- x 6954
Re: Mk1 C5 VTR alloy wheel trim required
There are several types of central plastic hub cap depending on the alloy you have fitted. If you send me a PM with your VIN I’ll let you know which one you need. Depending on the type they are relatively easy to obtain and not too pricey.
- x 3281
I have a Mk1 VTR, and the wheels on her are Hungaro style;
http://www.ebay.co.uk/itm/ALLOY-WHEEL-C ... SwrfVZP-KM
https://www.ebay.co.uk/itm/New-Genuine- ... Swr7ZW69sY
- x 6954
There were three types on looking, depending on Alloy:
The Monza 16"
Again, this is cheaper from citroen direct - £8.69 Inc. VAT brand new (Part 542104). The monkeys below are charging double for a used one!
https://www.ebay.ie/itm/Citroen-C5-Allo ... OSwxOFaf0N~ The Imola 15"
Brand new from Citroen is £10.42 Inc. VAT (Part number 542113) - below is a new genuine one for a couple of £s less:
https://www.ebay.co.uk/itm/CITROEN-C2-C ... 2806329642 The Hungaro 16"
As for these, they are charging almost the same price for a second-hand used one as a new one from Citroen! Current brand new price for the Hungaro from Citroen is £22.72 inc. VAT. (part 542116)
The Monza 16"
tontonjon
- x 9
Thank you! Yes, it's the Hungaro ones that I have. But the Monza ones are cheaper - do they fit in the same way, though?
More research...
More research...
- x 6954
They just snap in
- x 3281
While they do just snap in you must make sure they are lined up properly, otherwise they can get damaged. There are alignment tabs on the opposite side (up at the top of Marcs' picture, IIRC) that must go into the relevant place on the rim. On the attached picture this place is at the 2 o'clock position;
https://www.ebay.co.uk/itm/Genuine-Citr ... Swu4BV6Hti
The notch where you would place something to lever off the cover (lowest edge, Marcs' picture) lines up with the air valve on the rim.
wurlycorner
- x 271
Hell Razor5543 wrote: 25 Feb 2018, 18:41 While they do just snap in you must make sure they are lined up properly, otherwise they can get damaged.
Yep - the mrs C2 has suffered from that not being done correctly in the past
I will say that I have some sympathy with the previous culprits though, because the C2 has two of those locating recesses rather than one and it's not exactly easy to get them to pop in evenly all round at the same time - and unless you do, one or more of the the tabs don't go into the recesses and that's what causes it to flex and crack
Iain
CX DTR T2 Safari (silver)
Iain
tontonjon
- x 9
Bought a new one online. £22 including postage. Amazingly, second had wheels including the centre can be got for about £10 more... Next time, perhaps!
