Gabby is broken, fuel pump leak
- x 8408
Re: Gabby is broken, fuel pump leak
I did the timing belt when I owned her Davie... No need to disturb the belt when changing pumps
ekjdm14
- x 263
Missed this thread. Going back to page 1 a mo, I replaced the dizzy head seal on Black using mainly Jim's guide for reference as well although I did the job in-situ. Nothing at all wrong with Jim's knowledge of these pumps if it enabled a first timer to do that... I think I need to have a thumb through MikeT's guide as well now since I hope to up the power on White eventually once the engine is proven sound finally.
Hope the cambelt can stay in place on Gabby and allow a quick and effective reseal. Also makes me realise how small my health problems are in the big scheme of things, hope you all stay well and don't overexert.
'96 ZX SX 1.9TD, White, 88k
'12 Mini freebie project
daviemck2006
- x 485
CitroJim wrote: 03 Feb 2018, 10:22 I did the timing belt when I owned her Davie... No need to disturb the belt when changing pumps![]()
I know the timing belt is very recent Jim, I’m worried that it may have been running under a shower of veg oil and that could cause it to slip. I’ve not spoken to my mate today, the car was dropped at his yesterday. I will find out tomorrow if the pump is off or not. Just wondering if the belt is covered in oil if I were to spray it with degreaser and then power hose it if that would be acceptable?
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
Peugeot boxer 2016
In the family
- x 8408
Luckily, timing belts rarely get covered in oil from a leaky pump Davie..
It only might get a little oily if the front (driveshaft) seal fails... If that's all that's failed on it then it can easily be replaced without disassembly...
If it is oily, replace without question - don't try to clean it...
