HHD Image for RT3 N3 eV (RT4)
407Dave407
New User
Unread post by 407Dave407 »
Hi ,
I have a faulty 2007 Coupe - RT3 N3 Headunit , think its called a RT4 but not sure.
RT3 D2A-N3
e2 03 06046
96640242YP
354149010120070
Was updated with 8.31 firmware.
The harddrive had failed , new one in and all ok. Then by mistake update disk in again but the CD player is flaky and gets to various points in updating and fails.
Bootrom etc all ok.
Tried to update from USB but no luck.
I see many have worked on these units upgrading to SDD and saving the HDD ISO drive image.
So I ask to those to please help by getting a ISO image of a working unit , I can then write that image to my new HDD.
Then setup vehicle settings if different using scripts.
Thanks in advance to anyone you can get the image done. Very Happy Smile
EDC5
x 130
Re: HHD Image for RT3 N3 eV (RT4)
Unread post by EDC5 »
Would it be possible to run a lens cleaner disc in the machine for a few mins before trying again with the firmware disc?
I'm assuming you're installing the firmware from scratch using the two small buttons on the bottom of the unit.
I have made a image of my RT4 hard drive and would like to share it with you but unfortunately it's on a computer at home (I'm currently at uni) so won't be able to get it for a month or so :(.
mkln
Unread post by mkln »
Hey, is that possible u still have it? I'm broken of searching this, my cf card won't start without clone and I am not sure I can recover anything from my hdd
x 6945
Is it the firmware you require for booting from? The Firmware should recreate the partitions on a CF card for you and can be run from USB on a C5 X7. I have V8.30 and V8.20.
ton4eto
New User
Unread post by ton4eto »
Hi! Can you upload the 8.20v firmware please because i cant find it nowhere. :)
Marck3d3
Unread post by Marck3d3 »
bonjour j'ai un modèle de navigation rt3 ev n3 q1 sur une peugeot 308 de 2008 Le disque dur est cassé. J'ai acheté un autre disque dur et j'aimerais demander votre aide avec l'image du disque dur pour ce modèle car je ne peux rien faire avec l'ancien disque dur. Merci.
x 5672
Please post in English!
Again, translated with DeepL:-
"Hello I have a navigation model rt3 ev n3 q1 on a 2008 peugeot 308 The hard drive is broken. I bought another hard drive and I would like to ask for your help with the hard drive image for this model because I can't do anything with the old hard drive. Thank you for your help. "
Marck3d3
Hello, I have a navigation model rt3 ev n3 q1 on a Peugeot 308 from 2008. The hard drive is faulty. I bought another hard drive and I would like you to help me with the hard drive image for this model, as I can't do anything with the old hard drive. Thank you for your help.
