Headlight Lens Cleaning
dave_xsara
(Donor 2021)
x 10
Unread post by dave_xsara »
As I'm tidying the Xsara up, the headlights need to get some attention.
I've done a search on here for headlight cleaning, but nothing has come up - so if this has been discussed before, please point me to the thread.
The lens for the headlights are what I would consider cloudy. The front of the bonnet is peppered with road debris, so I the lens would not have escaped abuse.
I've been looking into the methods shown online for cleaning the lens. Some recommend a kit which has a head attachment (i.e. 3M) and other recommend using various decreasing coarseness of sandpaper by hand to achieve the same outcome. The main thing to take from the things is that it is wasted effort if the UV film/protector is not applied immediately afterwards.
I suspect that the drill attachment would not be overly useful on the curved Xsara lens.
Has anyone done this previously on a Xsara and what method did they use?
hirsty
x 9
Re: Headlight Lens Cleaning
Unread post by hirsty »
:) Depending on severity, I have always used Brasso. Several applications may be required.. :)
hirsty
98 Xantia Mk2 2.0 16v Auto Exclusive 160k + Now gone to Citroen Heaven
2004 C5 Mk 1 2.0 8V VTR Estate - current. Now with leather.
x 1998
Unread post by Stickyfinger »
Curved lens/covers and not a problem as you can move your wrists.............
Oldpug
x 94
Unread post by Oldpug »
I`ve used normal cutting paste(like T cut) and an electric polishing mop. It worked a treat on various models that have failed an MOT on poor beams.
Michel
Unread post by Michel »
I used a 3M kit on a C1, a 207 and a C5 MK1, All of which have curved and odd shaped lights. Worked really well.
Zelandeth
x 1607
Unread post by Zelandeth »
T-Cut or Brasso worked wonders on the Cappuccino (only car I've had so far with the issue), think Brasso was slightly more aggressive.
Be very careful if using a power polisher to make sure you don't end up causing localised melting of the lens.
I tried one of the 3M kits on a friend's Ford...Can't remember if it was a Focus or Mondeo...My only memory was it being soul-destroyingly boring. Kit worked well enough, but I really didn't see any difference between that and Brasso really.
Just make sure to give it a really good coat of wax afterwards to help muck slide off when the roads are wet.
Current fleet:
x 1746
Turtle Wax Headlight Restorer (kit) works. Just use the cream cleaner if the cloudiness isn't too severe. Kit also contains abrasives and other bits and good instructions.
Mer car polish will also work, or T-cut. Use plenty of it, and lots of elbow grease (or a polisher).
Any yellowing will be at the surface, and should also polish out, more-or-less.
x 3296
A simple, low cost, and surprisingly effective method is to use a clean face cloth and a mildly abrasive toothpaste. It will need a lot of elbow grease, and a few applications (with tap water to rinse away the residue). OK, Michel did then use his own 3M kit (which works well), but the toothpaste made a reasonable go of cleaning the headlight lenses.
wurlycorner
x 271
Unread post by wurlycorner »
Yep, the 3M and Meguiars kits can be used on curved headlights, no problem
Alternatively you can just use different grades of sandpaper (yes really!) finishing with a very very fine grade (like they use for finish sanding paint lacquer) and then polish over with a standard car polish.
Iain
CX DTR T2 Safari (silver)
x 1746
Just a word of caution: don't use any sand/other paper with a coarse or medium-course grit. It could put scratches into the polycarbonate lens which you will struggle to remove. Stick with fine or very-fine abrasive, if liquid won't do the job. :!:
Spurious
Unread post by Spurious »
I did a good job on a Primera perspex light housing.
I used some 2500 grit wet sandpaper, then 3000 grit. Make sure it's well lubricated. Then plenty of T-Cut. Wax to finish off.
It took the best part of an afternoon and my fingers were aching afterwards. Headlights were shiny clean however...
Phase 2 Xantia HDi
Sold
Phase 1 Xantia Activia
Sold :(
Phase 2 Citroen C5
Sold
And a current semi-working MK1 C5 Hdi 110.
van ordinaire
(Donor 2017)
x 400
I thought I knew something about this, as it's a real problem most '90's Cadillacs & Sevilles in particular have such poor headlights (even the later HID equpped ones) they need all the help they can get.
A friend who did show standard polishing had limited success but got to the stage he was concerned about how much material was left but I'd had no success with any product, even marine plastic polish. Not been brave enough to try wet'n'dry though!
Citroens:-
'81 2CV Club :cry:
'05 C15 :!:
others:-
Jeep XJ Cherokees x 3 :?
'96 Cadillac Eldorado
'99 Cadillac STS :|
Bandit12
x 12
Unread post by Bandit12 »
T cut worked for me
2002 Citroen C5 2.2Hdi exclusive estate (sadly gone) :(
2009 Citroën C5 X7 2.0 hdi (136bhp) exclusive estate (Oh wow what an upgrade) 8-)
dave_xsara
(Donor 2021)
x 10
Did any of you use a UV sealant or a clear lacquer to finish the job?
x 1746
No, I didn't. Intense UV sunlight here, but I just give my (Toyota) plastic ones a Mer polish a two/three times a year; surface yellowing comes off each time.
