Hi all,
The charging warning light started to come on since yesterday morning - it's a bit intermittent that some times it goes off as it should after start up, other times stays on or then it comes back on and off as it pleases (but doesn't rapidly flicker or anything - once on or off, it tends to stay that way for a while)
I did a quick investigation and it charges ok (high 13V - mid/low 14V) when running and the battery is at high 12V with the engine off. The commute of 15km with lights on is no problem and after 8 hours of work, starting it up to go home, again is no issue.
I'm hoping it's some earth issue with the warning lamp (as there are a couple of pre-existing dash lamp problems) but want to make sure it's not the alternator/regulator.
Can anyone help me out with the pinouts for the alternator/regulator plug/wires and any other pointers pls?
I haven't got the hang of the wiring diagram and I'm not sure I ever will...
Cheers
Sam
PS it's the rolling drum type dash board, if it makes any difference.
GSA charging idiot light issue
sonoramicommando
- x 5
2006 C6 Exclusive 2.7HDi
1982 GSA Pallas
A couple of bikes
A boyracer car
1982 GSA Pallas
A couple of bikes
A boyracer car
- x 3298
Re: GSA charging idiot light issue
I would guess (based on my BX problem of a similar nature) the brushes are on the way out. When they failed on my BX many years ago I had similar symptoms. I was able to source a brushes block for around £15.
sonoramicommando
- x 5
thanks - do you remember how much of the brush was left compared to the new one?
I wonder if I can stretch it out to last a couple more months as I'm putting it on the market soon...
1982 GSA Pallas
A couple of bikes
A boyracer car
1982 GSA Pallas
A couple of bikes
A boyracer car
- x 3298
The brushes were pretty much worn out. The new brushes were quite a bit longer (but we are talking over 10 years ago, so I cannot remember by how much). However, it was quite easy to fit the new brush unit, as access was good (I did not have to take the alternator off the car).
wurlycorner
- x 271
Also check that is outputting DC only (not AC, which indicates the rectifier is faulty)
Iain
CX DTR T2 Safari (silver)
Iain
- x 1746
Note also that a working dash warning lamp (good bulb and connections) are usually necessary for the alternator produce a stable output. Dash lamp usually has a resistor in parallel with it, so that alternator still functions even if the lamp blows. Not likely to be your problem, if alternator output is good: DC, stable, and about 14.4v.
sonoramicommando
- x 5
Thanks guys - I'll check if I can get to the brushes without having to remove the alternator... Hopefully the storm dies down this weekend a bit.
1982 GSA Pallas
A couple of bikes
A boyracer car
1982 GSA Pallas
A couple of bikes
A boyracer car
sonoramicommando
- x 5
ok with the warning lamp on, the voltmeter shows what the alternator/battery is supposed to be doing. ~12.5VDC with motor off, ~14.3VDC with motor running.
Changed to VAC and it showed ~30, not sure what it means but probably not what's it supposed to do?.
1982 GSA Pallas
A couple of bikes
A boyracer car
1982 GSA Pallas
A couple of bikes
A boyracer car
- x 1481
Ignore the AC reading, your meter is not designed to read DC with AC superimposed.
I think that it is fairly safe to assume that the problem is with the brushes of regulator in your alternator.
sonoramicommando
- x 5
ok thanks - looks like I'll have to take the alternator out.
cheers.
cheers.
1982 GSA Pallas
A couple of bikes
A boyracer car
1982 GSA Pallas
A couple of bikes
A boyracer car
- x 1746
sonoramicommando
- x 5
Is it me or the GSA wiring diagram completely useless?
1982 GSA Pallas
A couple of bikes
A boyracer car
1982 GSA Pallas
A couple of bikes
A boyracer car
