Citroen C5 2003 dripping fluid from passenger rear suspension ram boot
- x 1463
Re: Citroen C5 2003 dripping fluid from passenger rear suspension ram boot
I think that the rear of the car needs to be on stands with both rear wheels hanging down to allow access for this job. You may be able to use your ramps under the sills, with suitable wood blocks to spread the load.
spiff
- Fallen Hero
- x 19
The clip the other end just holds the boot in place.lexi wrote: 25 Dec 2017, 12:33 The worst part of all this is the pin that goes through the unit. It either comes straight out or is totally seized. I have the remains of a pin in one of mine. Despite grinding and hardening tool steel punches of clearance diameter.............it remains in there!
Does the pin that goes through the unit hold the other end of the piston ?
If so and you still have part of the old one in there, how did you get the new pin to do its job ?
Did you perhaps drill another hole ?
God Bless Spiff
wurlycorner
- x 271
The suspension needs to be set onto lowest setting with the wheels off the ground and hanging - otherwise the push rod will either be held under full compression under pressure (suspension on full height/wheels on the ground) or pushed right in between the trailing arm and the inside of the piston (suspension on lowest setting) and in either of those scenario's, you won't be able to get it out.
It doesn't matter which end you disconnect first, but you might as well start with the trailing arm end, as that is likely to be the most difficult.
The pin can stick. I didn't have a problem on my C5 with it particularly, but have previously had a problem on CX's.
Sticking a screwdriver through the hole in the inner end (where you pull from) so you can pull with both hands (one either side) of the pin helps IIRC. Also if you clean off the outer end of the pin first (scotchbrite/emery cloth/sand paper) to remove any dirt/corrosion from the pin, that will mean once started it will pull through the hole in the trailing arm/push rod without any problems.
Nothing else will move around while you're removing the pin or push-rod, provided you have the car/suspension set up as stated.
Iain
CX DTR T2 Safari (silver)
Iain
lexi
- x 133
spiff wrote: 27 Dec 2017, 19:43The clip the other end just holds the boot in place.lexi wrote: 25 Dec 2017, 12:33 The worst part of all this is the pin that goes through the unit. It either comes straight out or is totally seized. I have the remains of a pin in one of mine. Despite grinding and hardening tool steel punches of clearance diameter.............it remains in there!
God Bless Spiff
Hi Spiff
I got the pin out of the torn boot side and replaced that. Because I am a good bloke
I will do it this summer and change all the LDS. No problems with car, after doing lots of the jobs needed after 100k miles.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
spiff
- Fallen Hero
- x 19
wurlycorner wrote: 27 Dec 2017, 21:21 The suspension needs to be set onto lowest setting with the wheels off the ground and hanging - otherwise the push rod will either be held under full compression under pressure (suspension on full height/wheels on the ground) or pushed right in between the trailing arm and the inside of the piston (suspension on lowest setting) and in either of those scenario's, you won't be able to get it out.
Do all four wheels have to be off the ground or just the rear ones ?
God Bless Spiff
wurlycorner
- x 271
Just the rear
Iain
Iain
spiff
- Fallen Hero
- x 19
Thank you all gentlemen for your help : )
I think I am all set as long as I can get the car to drop to low.
This leak was discovered while plugging in a replacement sensor at the rear, to see if it would correct a problem with the pump intermittently not running when it should.
Serious Suspension fault comes up.
The pump itself is fine.
After being parked over night it is normally OK until driven a couple of miles, or if the raise or low setting is selected it tends to trigger the fault.
I may try the front height sensor before doing the boot.
Found a boot on eBay which should arrive by the 2nd of January, £9.75 with postage : )
Next thing is a Lexis, I have a WXP laptop being donated : )
Will post results.
God Bless Spiff
Will post results.
God Bless Spiff
spiff
- Fallen Hero
- x 19
Just a couple more questions as the boot has arrived super fast : )
Can the job be done with out getting under the car, by removing the rear wheel and doing it from the wheel arch ?
I am only going to be doing one side so can I just lift that side ?
God Bless Spiff
God Bless Spiff
wurlycorner
- x 271
You can do each side independently, yes - although you will need to have both wheels off the ground together I think anyway, so might as well do both at the same time? (Once you've done the first one, you have 'the knack' and the second one is mega easy!)
There is no way you could do the job without getting under the car - you will be on a hiding to nothing, fumbling about blind trying to remove/replace the pipes and remove/refit the clips and working at completely the wrong angle.
Iain
Iain
spiff
- Fallen Hero
- x 19
Thank you for that, both wheels off the ground and do the job underneath, Oh well I could but hope : )
God Bless Spiff
God Bless Spiff
spiff
- Fallen Hero
- x 19
More problems : )
A quick recap no leaks but Series Suspension Fault.
Fault occurred after a few miles or using the rise and lower switch, pump then will not run.
Pump tested OK
Purchased a height sensor to try.
Last ride before trying sensor car sunk at rear over trip, very bumpy ride back.
Looked under to see driver side suspension rear boot dripping, put bowl under.
Ordered new boot.
Boot arrived Joy : )
Car left over Christmas, today I thought first I will see if the pin will come out.
The rear had sunk a lot at the back and the pump ran longer than normal, but eventually it came up.
Put on ramps, the pin is nice and loose : )
I decided to get a new clamp for the other end of the boot, a screw instead of the type fitted before doing the job.
That lot is under control but new problem is : -
Noticed than now the area round the centre sphere was soaked in fluid, sorry that image is out of focus it was wet and cold and the light was fading.
It had even spread to the height sensor, see images.
I tried all the junctions round it including the sphere, but all are tight.
I had cleaned a lot of the fluid off before taking the picture, but could not see where the fluid is coming from.
Any Idea's : )
God Bless Spiff
Pump tested OK
Ordered new boot.
Any Idea's : )
God Bless Spiff
- x 1463
It is possible that your root problem is a leaking ram. The leakage is being contained within the boot, but (particularly when going over bumps) the leakage rate is great enough that it is pressurising the low pressure return line, causing fluid to escape wherever it can.
spiff
- Fallen Hero
- x 19
Thank you for your reply : )
Where is the fluid round the sphere coming from ?
As far as I know there is not a low pressure return round there ?
It looks as if the breather pipe from the ram boot goes into the same casing that is above the sphere.
Is it possible and are you saying that the original Serious Suspension Fault warning is tied up with the ram leaking, pressurising the return system which has just got worse ?
This is forcing fluid via the breather pipe into the void above the sphere which is then leaking over the sphere ?
God Bless Spiff
God Bless Spiff
wurlycorner
- x 271
The breather pipes from the cylinder boot, vents into the subframe cross member (the pipe litteraly just pokes through a grommet in the cross member and then stops).
Is it possible that the split in the boot is causing fluid to be sprayed onto the centre sphere, when the suspension moves???
I would certainly start with what you already know is faulty (the gaitors) and give all the gubbins around the centre a good wife over clean/dry, then keep a close eye on the car to see what happens. That will eliminate one possible cause of the leak and if the fluid reappears, it should allow you to see exactly where it's coming from.
You really, really, MUST get the car into a lexia to read the fault codes in order to diagnose the "serious suspension fault". Anything else (changing random bits) instead of doing that, is just wasting time and money and potentially causing more problems (changing height sensors could just result in throwing out the height settings).
Iain
Iain
dnsey
- x 19
IME, it's quite normal for a little misting from the breather to gradually accumulate inside the crossmember, which has a drain hole directly above the centre sphere block.
Mine gets a degrease just before the MOT each year to avoid difficult questions, but I've never had to top up the fluid.
