A lull in the festivities here ... and a few Bitron places.
My 1995 petrol Xantia had the Bitron under the bonnet … as in the first photo.
HELP!! Xantia Cooling Fans Driving me nuts!!
Clogzz
- x 40
Re: HELP!! Xantia Cooling Fans Driving me nuts!!
electronmirror
- x 31
Unfortunately all photos are invisible
Ted
2010 C5 2.0 diesel(163) Exclusive Tourer (133,509miles)
1999 Xantia Exclusive Estate 110 Hdi Mauritius Blue with self peeling lacquer finish (276,174miles)
1991 XM Prestige 2.0 Auto(157,000 miles) gone but not forgotten
- x 1450
It is likely that your car has the early single wire design. See viewtopic.php?f=3&t=26923&start=15 There is a link to a schematic of both versions in that topic.
kiwifrog
my brown plug has 2 wires but my blue has 1 wire ( early 1.9 TD by the way )
Clogzz
- x 40
wrote:Unfortunately all photos are invisible![]()
It took me over an hour to get that far.
How does this site work by now, and who's in charge ?
Reason: Quote tags fixed
- x 8363
The Admin Team... Mike (xantia_v6), Chris (white exec), Steve (Myglaren), Richard (RichardW) and Marc (GiveMeABreak) ..
They can be got hold of by hitting the 'Contact Us' link at the bottom of the forum page
Kiwi, I've not forgotten to delve into my documents and circuits and as soon as I'm in their vicinity I will...
- x 5671
Clogzz wrote: 28 Dec 2017, 12:20wrote:Unfortunately all photos are invisible![]()
Sent you a PM with a bit of guidance.
If you are still struggling email the photo's to me and I'll edit them in to your post.
saeedm
- x 16
though it is late to answer. but for guys that have this problem:
you have to understand how cooling fan works from 0 to 100. then diagnose the problem
and it is described in here:
http://www.peugeotlogic.com/workshop/ws ... fanop1.htm
saeedm
- x 16
recently i got this problem too.
i checked relays and sensors. the problem was not from any of them
after that i was testing wires and wiggling all cooling fan harness suddenly fans stopped working!! cos engine was cold so it is good sign...
finally i found that the all of problems was from this connector:
when i pushed connector together. every thing work correctly.
lots of problem are caused from connector like airbag warning light caused from seat connectors! so with wiggling or reconnecting them problem will be solved.
over time connectors pins get loss and the pins losses their spring force that needed for electric connections, caused from vibrations and something called -Plastic Deformation-.
like my xantia that is over 17 years old!!
solution: change connectors or solder wires together
