Yes I have... No good I'm sad to say but I do have a Sealskins skullcap and that is just wonderful... Keeps my head really toasty warm on the coldest of days and slips under my helmet a treat
Heated Rear Screen issues! - Xantia
- x 8431
Re: Heated Rear Screen issues! - Xantia
Rhothgar
- (Donor 2026)
- x 222
Timmo wrote: 28 Nov 2017, 17:52 Have you tried the sealskins gloves jim? I have a pair of silk liners too for the chilly days on my normal l full finger gloves, the sealskins are a bit thick and cumbersome for off road riding! That and my hands get hellish hot in them!![]()
Second Timmo on that. I use Sealskinz but don't have any silk liners (which apparently make a huge difference and probably stop your hands sweating!)
- x 8431
I must try some silk liners... Thanks for that tip both
Timmo
- x 168
We layer up our bodies but never think of the same for hands!
'58 C2 Code
'58 partner teepee outdoor
'58 C2 Code
- x 3298
I bought (for my Mum, for Christmas) two pairs of heated gloves (battery operated, 3 AA batteries each), that will heat the fingers (most just heat the back of the hands), as cold weather causes her fingers pain.
- x 8431
True! Now I think of it, I've had the best results of all when wearing my thin running gloves under my normal winter bike gloves but even then it's not perfect as like your mum James, I suffer terrible finger pain in the cold...
Thing is with cycling gloves is the need to retain a lot of digital dexterity for braking, gear changing and not least being able to grip the bars...
That rules out anything bulky and/or stiff; this effectively rules out any artificially heated ones...
Oddly, I have no problem with cold feet...
- x 2006
Re; your feet. That is because the muscles in your working calf muscles are effectively a pump for the return flow.....or leak back
....so increasing the low pressure in the veins (which have non-return valves btw) and thus allowing for increased blood flow.
Timmo
- x 168
Which is odd as my feet often get cold when riding with either merino liners or thick woolys under my sealskins yet my hands are Generally toasty!
'58 C2 Code
'58 C2 Code
- x 8431
Stickyfinger wrote: 29 Nov 2017, 09:05 Re; your feet. That is because the muscles in your working calf muscles are effectively a pump for the return flow.....or leak back....so increasing the low pressure in the veins (which have non-return valves btw) and thus allowing for increased blood flow.
Thanks for the explanation Alasdair
We are total opposites! maybe we ought to swap hands and feetTimmo wrote: 29 Nov 2017, 09:20 Which is odd as my feet often get cold when riding with either merino liners or thick woolys under my sealskins yet my hands are Generally toasty!
Timmo
- x 168
Haha! Sadly then, one of us would be toasty and the other frozen!
'58 C2 Code
'58 C2 Code
