Fuel Economy
paranoid
Unread post by paranoid »
If I do purely stop start all month I don't get a lot more than you, but if I do a couple of decent journeys it sipps fuel and the mileage shoots up.
crapday
Unread post by crapday »
just noticed that the air filter was not connected to the tubbing underneath it, would that make a difference.
weety
Unread post by weety »
shouldnt do, i never managed to refit mine on my m reg one after i had to take it off...never seemed to make any difference to the economy
jeremy
x 3
Unread post by jeremy »
If the air cleaner is disconnected it probably won't affect the vehicle at all, and indeed may actually improve performance as there is no drag imposed by the filter. However these things are there for a purpose and its purpose is to prevent abrasive particles getting into the cylinder bores and causing premature wear.
Driving in the damp probably won't do much harm, driving on hot summer days in sandy areas may.
Jeremy
philhoward
Unread post by philhoward »
Do you get excesive smoking (soot) out of the exhaust if you put your foot down? Could be still thinking its cold; is the cold start enrichment playing up?
jeremy
x 3
On rotodiesel pump the cold start device (waxstat) fails in the hot position. Somehow I think the Bosch will as well as the cable contracts when cold.
In fact if I disconnect it on my BX TD the engine just starts very slowly and is prone to stalling. Set properly on ZX 1.9D hot idle is 750 and cold is about 950. (Bosch may be faster)
jeremy
Tuftus
Unread post by Tuftus »
Just out of interest, what range do all you other Xsara HDi owners get from a tank?
Andy
crapday
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by philhoward</i>
no, I did a italian tune and cleared all the soot so now no more smoking for the time being.
crapday
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Kowalski</i>Air and fuel filter problems don't tend to cause big drops in fuel economy, they can cause small drops. My Xantia TD does around 600 miles on a tank. 350 miles from brim to brim would indicate 25mpg. 25mpg indicates a serious problem.<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
what sort of 'SERIOUS PROBLEM"[V]
paranoid
Bro in laws Xsara estate 1.9td used 99% on the motorway motorway gets minimum 650 miles to a tank
robsons
Unread post by robsons »
Hmmm my Volcane TD only gets 370miles to a tank - 90% motorway at 3500rpm+
paranoid
Checked with in law this morning average over the year works out to 620-630 a tank
