CX GTI Turbo. Thinking caps on!
Bilkob
x 47
Re: CX GTI Turbo. Thinking caps on!
Unread post by Bilkob »
Hmm, don't THINK so as it does bloody go when the bonnet is shut for driving!
But I'll check
wurlycorner
x 271
Unread post by wurlycorner »
Sounds light fuel starvation/evaporation when it gets hot.
I would check all the fuel lines for any visible cracks/splits/loose joints as a starting point and then maybe something like squirting easi-start over the system bit by bit (again, when it's hot).
Iain
CX DTR T2 Safari (silver)
Bilkob
x 47
Does anyone know the part number for the fuel pressure regulator? CX GTI T1 (series 2)
x 1459
Unread post by xantia_v6 »
What drives the ignition coils on this setup?
You could try wrapping various components with a wet rag to see if the symptoms are delayed.
wurlycorner
x 271
xantia_v6 wrote: 21 Nov 2017, 08:21 What drives the ignition coils on this setup?
Thanks to the wonders of Citroen at this time, on this model, it could be any one of three setups :lol:
Single pickup or dual pickup flywheel and tdc sensors, via the AEI unit.
Iain
Bilkob
x 47
Mine has got twin flywheel sensors. They are now replaced with Ford items
I'm determined to sort this out, as it's such a great car, and ay help others too
So, overheating coils?
Knock sensor?
Air flow meter?
Cylinder head temp sensor?
Fuel pressure regulator?
Fuel pump?
A curse?!
wurlycorner
x 271
Have you looked at my suggestion yet? You've jumped straight back to all the electrical items there...
And the knock sensor will only retard the ignition by a small amount and only if it hears knock (it is nothing more than a microphone on these really). It will not cause the engine to stall and cut out. Just unplug it if you have any concerns it is - from memory that should have no effect.
Iain
Bilkob
x 47
Ok. More evidence.I've sprayed all the fuel, air, etc lines and pipes and joints in the engine bay with easy start/WD and not a jot of difference
I did find d a split in the rubber T that comes off the boost pipe, utility fixing this made no difference
I've also learned that it WILL cut out with the bonnet open too, same symptoms as closed
However, tonight I sat in it and waited for it to happen.
Just before it cuts, it stutters and if you catch it on the throttle it will splutter and keep going. When the spluttering gets really bad, the tacho needle starts jumping around and the throttle pedal becomes unresponsive
After it dies, it restarts 9 times out of 10, but sometimes with the tacho jumping and unresponsive throttle, sometimes not
I've read that these are classic symptoms of AEI issues but I've tried another one and that did the same!
Over to you lot!
Zelandeth
x 1601
Unread post by Zelandeth »
The tacho jumping around immediately shouts to me of cranshaft position sensing issues.
Worth getting a scope involved and seeing if you've got a clean signal arriving at the ECU?
These don't have the weird warmup regulator setup like the K-Jetronic cars do they (which vary the mixture as the engine warms up by varying the fuel pressure)? If so, they can cause some downright strange behaviour when playing up. Talk of airflow meters though suggests its a more advanced setup...
Current fleet:
Bilkob
x 47
Ok, so, a few more clues.
The car seems to get 'less pleasant' to drive the longer it is running. It's as if, as it warms up, not to operating temperature but after extended running, everything just gets a bit bit 'less smooth'
Also, if you've pinned it's ears back (!) and then come to a stop, idling , the oil light flickers on, but blipping the throttle see it go out
Also, the more/harder it's run, there's a faint burnt oil smell, but there's no leaks onto or near the turbo
Today, I changed the coils back to the original single pack that was originally on the car and it made NO difference
The car has no overheating issues, fans cut in at about 90 c and the temperature falls back to 80 quite quickly
I've changed oil and filter ( that was fun)
I'm now wondering if I should try and fit an inline fuel pressure gauge?
Has anyone done this?
Also, with the cutting out, it'll now restart pretty much straight away (lower ambient?) But still with flicking tacho
x 1746
Oil light flickering on might just be idle speed too low (or result of running badly when hot), especially after a 'hot' run, when the oil will be thinner. Reassuring that it goes out as soon as engine speeds up.
Tacho flickering does suggest crankshaft (flywheel) sensor. Citroen speed sensors (flywheel, distance...) fairly well known for misbehaving.
Possible that the sensor that triggers tacho is also feeding other things, including engine ECU.
Check sensor tip for wear/damage and steel dust/debris - tips are magnetic. The closer the sensor tip to the metal peg/whatever that it's triggered by, the better. 1-2mm usually does it. Check sensor connector for cleanliness and contact too; signal produced is minuscule.
Bilkob
x 47
The sensors are new Ford items, the connectors were spotlessly clean. Where is the sensor that triggers the tacho?
wurlycorner
x 271
Ah, Now you tacho bouncing, I agree this now sounds more like flywheel pick up and/or other aei system related fault and it must be something breaking down in the heat.
Could potentially be low voltage causing the electronics to fail? Try fitting a voltage meter somewhere so you can see if the alternator output voltage is dropping off when the car gets hot and at idle.
How like-like were the replacement Ford flywheel sensors and why were they replaced in the first place? We're the old ones definitely u/s? I would suggest swapping back to the oem items. Also did you check that the gap between the new sensors and the flywheel teeth and the TDC marker were the same for the new as on the original?
Iain
wurlycorner
x 271
If you want to pop over one day next weekend I don't mind spending a few hours poking about on it with you if you like?
Iain
wurlycorner
x 271
Just wondering how things are getting on?
Iain
