C5 Door Switch Location
x 6950
Re: C5 Door Switch Location
EDC5 wrote: 20 Nov 2017, 10:03 Just for reference the replacement part I got wasn't the same part number, is it possible that all X7 door lock mechanisms are the same?
Hi Elis. They are different depending on whether they are left or right hand drive, and additionally, it will depend on the type of central locking fitted:
There are 2 types of locking depending on trim / Country:
  • Simple Central Locking
  • Central Deadlocking
Additionally, they were also replaced with a different part from 1st March 2010 and again from 1st January 2012.
EDC5
x 130
Unread post by EDC5 »
Good point, I can test whether my new lock mechanism has deadlocking by trying to open it with the key... if it doesn’t open then deadlocking is working, correct?
x 6950
The UK Right Hand Drive models I think should have Deadlocking. Use the fob - one press to lock second press to deadlock. If you have the window down, deadlock and then try and open door handle from inside - if it doesn't - deadlocked. (but temporarily disable the Ultrasonic sensors first using the button - within 10 seconds of switching ignition off) so you don't upset the neighbours!
centurus2400
x 4
Unread post by centurus2400 »
Blimey, it's not easy to read the VIN on a dark wet afternoon...
It is, I hope, VF7**************[VIN obfuscated, can be read by forum staff] :)
x 6950
Ok so here are the parts:- Item 1 in the diagram
Original Part Numbers:
Right Side 9136 EG
Left Side: 9135 CX
Replacement Part Numbers:
Right Side: RP 9800618580
Left Side: RP 9800618480
centurus2400
x 4
Thank you most kindly :-D
pierrepoppi
Unread post by pierrepoppi »
The problem for me is I'm locked out of the car with the only key still in the ignition switch. Short of going to a locksmith and getting a key cut from the factory code, is it possible to break into it? it's a 2005 C5 HDI estate.
x 6950
I think you'll need to speak to a local locksmith - or get a key made up - as to be honest, it's not something we would want to put on a public Forum if there was a way.
x 1061
Unread post by wheeler »
As the key is visible your best bet is to wedge the top of the door frame to create a gap & fish the key out using a long rod. If its a remote key (and the car battery is not now flat) if you can hook the key out & onto the seat or floor use a long rod to press the unlock button on the remote.
x 5690
With a long enough rod you may be able to push the lock button on the dash.
How did you manage to lock the keys inside if you only have one?
moizeau
x 423
Unread post by moizeau »
myglaren wrote: 05 Jan 2022, 13:13
My C4 locks itself if the key is left in the ignition. No key in the ignition and it doesn't.
Pete
x 1061
myglaren wrote: 05 Jan 2022, 13:13 With a long enough rod you may be able to push the lock button on the dash.
On many modern cars interior electronic lock buttons go dead a few minutes after the car is locked. Cant remember if this is the case with early C5's or not.
If the car is deadlocked then it will definitely be disabled.
x 5690
moizeau wrote: 05 Jan 2022, 14:44
That is a clever trick.
If you do get in it may be possible to disable that.
Mine will only lock itself if it has been unlocked but a door or boot not opened.
The two Mk. 1 C5s were the same.
pierrepoppi
GiveMeABreak wrote: 05 Jan 2022, 10:17 I think you'll need to speak to a local locksmith - or get a key made up - as to be honest, it's not something we would want to put on a public Forum if there was a way.
I've all but given up on this problem. Our local dealership wants proof of ownership before they order another key, they say It's a directive from PSA.
pierrepoppi
myglaren wrote: 05 Jan 2022, 16:51
Mine will only lock itself if it has been unlocked but a door or boot has not opened.
This one is a series 2 with the facelift front, I think the battery may have been under 9 volts, I heard the lock activate just as I let go of the door. I bought the car second-hand with only one key, the other one was apparently lost. I don't want to damage the door frame but it looks like I might have to use a wedge to pry open the frame to get the rod in.
