Electric vehicles-Conversions
- x 1751
Re: Electric cars/vans/bikes-Conversions/Secondhand..etc
Agree that we're already "taxed per mile" simply because of the high level of tax incorporated into the pump price. Thirstier cars pay more per mile, and there's some environmental and social advantage in that: a decently progressive tax, levied to a large extent as per the driver's ability to pay.
Suggestions so far of tax per mile for BEVs seem simply to replicate that - the more you drive, the more you pay. Throw in some not-too-difficult tracking technology, and we have the basis for some sensible 'road pricing', which should be able to mop up congestion zones and have an impact on rush-hour issues.
All something not to get upset about, I would think.
- x 2941
Got an email today from Vespa re their new Vespa Elettrica scooter, haven't had time to look any further yet.
- x 5671
MikeT wrote: 09 Nov 2017, 18:44 I've come to the conclusion the light grey haze mine emits must simply by all that soot converted to ash and now view it as good thing™ instead of a worry.
I estimate my DPF is much cleaner and more efficient than when it came to me and intend to look after it by giving it a good blow-through, particularly after a regen when the ash content would likely be it's most compacted.
I am presuming that the slight grey haze that mine produces when pushed hard is unburned diesel.
- x 1751
Grey haze particularly visible at night, in headlights of the following car, under heavy acceleration.
- x 2941
Unburned fuel usually caused by pump timing being 'late'.white exec wrote: 10 Nov 2017, 22:15 Grey haze particularly visible at night, in headlights of the following car, under heavy acceleration.
MikeT
- x 232
myglaren wrote: 10 Nov 2017, 17:45MikeT wrote: 09 Nov 2017, 18:44 I've come to the conclusion the light grey haze mine emits must simply by all that soot converted to ash and now view it as good thing™ instead of a worry.
Soot?
- x 2941
- x 695
So, Tesla has announced their first truck - an articulated lorry in UK speak:
http://www.bbc.co.uk/news/technology-42021713
I haven't had time to read everything announced but a few talking points:
* Will go into production in 2019 (so being Tesla, lets call that 2020 maybe 2021 as they have a lot on their plate
* Can accelerate from 0-60mph in 20 seconds while pulling its maximum 80,000 pound load. Holy cow! Move aside Diesel!
0-60mph in 5 seconds unloaded with just the cab.
* 500 miles of range on a single charge, when hauling a full 80,000 pound load at "highway speeds".
* Cost ? Who knows...
* How long to charge such a (presumably) huge battery ? 400 miles of range added in 30 minutes using a Tesla "Megacharger".
* Drivers position in the middle instead of one side ??
They also announced the 2nd generation Tesla Roadster:
* 620 miles of range on a single charge at "highway" speed.
* 200kWh battery pack.
* 0-100mph in 4.2 seconds. Yes zero to 100mph not 0-60.
0-60mph in 1.9 seconds. Fastest (acceleration) production car ever they're saying.
* Four wheel drive with one motor at the front (with a diff) and two at the rear allowing for controlled torque steering. (Similar to the Rimac concept one)
* 10,000 Nm of torque.
* Available in 2020. (So lets say 2021...)
They sure know how to push boundaries.... lets hope they deliver on their promises though and don't go bust from over extending themselves.
They generally do, although they are nearly always behind schedule...
Some videos.
9 minute sound bite version compiled by the verge:
Full Tesla presentation:
Some videos.
- x 1485
Some of those figures are pretty mind bending!!
On the truck battery... HGV 'efficiency' seems to be around 10MPG. Let's take that as 4 times that of your ION. You are getting 3-4miles / kWh, so truck is going to get 0.75-1 miles/kWh on a direct reverse comparison, that puts the battery at somewhere around 500kWh? This link suggests such a battery (in Li-Ion tech) may weight 23 tones, which doesn't leave a lot of space for Cargo!! If the Megacharger does 80% in 30 mins that gives a power output of around 800kW - say 1 MW including losses and the cooling, will need a fair sized cable off the grid, and a pretty big battery cooler
Mind you, we've got a couple of 6MW motors here, they have to ring the grid up before they try and start them
Edit, forgot the link: https://qz.com/1131928/elon-musks-tesla ... d-to-know/
- x 695
You can say that again.
I don't really follow your numbers here - how is my Ion 4x 10MPG ?On the truck battery... HGV 'efficiency' seems to be around 10MPG. Let's take that as 4 times that of your ION. You are getting 3-4miles / kWh, so truck is going to get 0.75-1 miles/kWh on a direct reverse comparison, that puts the battery at somewhere around 500kWh? This link suggests such a battery (in Li-Ion tech) may weight 23 tones, which doesn't leave a lot of space for Cargo!!
Another factor you have to consider is that ICE trucks waste a huge amount of energy in braking slowing down their heavy loads. An EV truck will be able to regenerate a large portion of that kinetic energy (also gravitational potential energy when you descend a hill you just climbed) and they make a big deal about that in the presentation. The effect of strong regenerative braking is that as you increase the load the energy consumption doesn't go up proportionally to the increase in weight.
So for example if a cab alone weighs 10 tons and you add a 20 ton load to make it 30 tons total, the energy consumption of an ICE truck would go up by 3x but for an EV with strong regeneration it would go up much less, maybe by 1.5x depending on how good the regeneration is. It takes more energy to get rolling or climb a hill with a heavy load, but you get more regenerative energy back into the battery when you decelerate or descend a hill..
There's no way a 500kWh battery alone weighs 23 tons!
Now tell me how heavy the motor, gearbox, differentials etc are in a comparable ICE big rig ? Pretty darn heavy I'd say, probably a couple of tons.
Also consider that the cab on its own can do 0-60mph in 5 seconds, but with an 80,000 pound additional load it takes 20 seconds. No way could a cab that weighed nearly 30 tons on its own do 0-60 in 5 seconds.
Another little tid bit of information - the truck has 4 motors, one on each of the rear wheels - they're apparently using the exact same motor as that used in the Model 3 - just 4 of them.
BTW if a 500kWh battery sounds huge for a truck - they announced that the new roadster has a 200kWh battery.
They talk about this in the presentation - the Megachargers are battery buffered with an onsite stationary battery array to buffer the load from the grid - so most of the 30 minute charge comes from the onsite batteries and the grid then replenishes those onsite batteries over many hours to spread the load. They're actually already doing exactly this at some of the very large supercharger sites.If the Megacharger does 80% in 30 mins that gives a power output of around 800kW - say 1 MW including losses and the cooling, will need a fair sized cable off the grid, and a pretty big battery coolerMind you, we've got a couple of 6MW motors here, they have to ring the grid up before they try and start them
The scale of some of this stuff is pretty hard to digest, that's for sure.
- x 695
https://www.forbes.com/sites/alanohnsma ... d2871238c2
So the cab weighs about 10 tons in total and the 80,000 pound maximum load includes the cab itself ? That would make sense.Creating a viable, 10-ton, battery-powered truck capable of hauling up to 60,000 pounds for hundreds of miles, with batteries that can be recharged in under an hour and with durability to last for years is a gamble that perhaps only Musk, a remarkably shrewd marketer, would want to undertake right now.
harryp
- x 73
OK, unsure regarding the "pay per mile" scenario.... DVLA recon 30% of road vehicles are untaxed. This actually means that they cannot adequately police the system - no surprises there! So who is picking up the shortfall? Guess it has to be the poor law abiding motorist yet again.
It's high time the law (joke) actually penalised people who broke the law - in all aspects. OK build more prisons and pay for and train more police. Otherwise shut the f@@k up and pass no more laws - the Govt cannot even be bothered to properly enforce the ones we currently have
Rant over, but it does make me cross - all this waffling when they know that the end result will be nothing at all. Good posturing??
Regards, Harry
2000 Nov Forte HDI 110 hatch in Wicked Red; currently SORN
2000 Mar Exclusive HDI hatch in Quartz; currently SORN
2013 C4 Picasso Excl E
Peugeot 207cc 1.6 Roland Garros
- x 2941
That '30% are untaxed' figure you quote seems extraordinarily high to me, does that include all the cars that are sorn or sitting in car dealerships waiting to be sold?
This from the news report:
"At least 755,000 untaxed vehicles are being driven around on Britain’s roads."
- x 1751
Worrying. So if 30% untaxed, how about un-MoT'd and un-insured ?
You'd have thought that with ANPR, this lot would have been caught up with by now.
How about going real Big Brother, and making it impossible to forecourt-refuel a vehicle without all/some of these? What would be the justification for not doing this?
After all, it's the rest of us that are paying for the evasion.
Discuss.
Discuss.
Michel
The news report is b0ll0cks, as usual.Gibbo2286 wrote: 18 Nov 2017, 10:59 That '30% are untaxed' figure you quote seems extraordinarily high to me, does that include all the cars that are sorn or sitting in car dealerships waiting to be sold?
It's 1.9% of vehicles, which includes those not declared SORN. It also declares RFL exempt vehicles where the owner hasn't "retaxed" them even if it costs zero.
Of the unlicensed vehicles identified in the survey:
52% had been unlicensed for 2 months or less
34% has changed hands since September 2016
51% were more than 10 years old
9% were less than 2 years old
I suspect a lot of this is down to the confusing way that cars change hands now and tax gets cancelled upon sale of a car.
Stats from the report itself, available from https://www.gov.uk/government/statistic ... stics-2017
