- Disconnect Battery
- Disconnect the connector for the blower control module at (b)
- Rotate and detach the blower control module in direction shown at (c)
- Remove the module (2)
Glovebox removal access blower resistor pack
- x 6945
Re: Glovebox removal access blower resistor pack
Gary, that is just the parts diagram - here is the location (note this again is shown on a left hand drive, but the location will be identical - just on the passenger side well.
crapday69
- (Donor 2017)
- x 59
I found it lol. How to I tell if its not working, is it just replace and see. I got it out, is there a way to open it up to see the gubbins inside.
thanks for your help, i couldn't have managed this without your help Marc.
Gary.
Gary.
crapday69
- (Donor 2017)
- x 59
I can get one delivered from ebay tomorrow for £25. Is likely to be the culprit. I know you cant be sure but this seems to be a problem with Citroen.
Just off the for to Citroen Glasgow, they quoted £135. They say it costs them £90.
If this part fails will this stop the blower from working or will the blower be stuck on full speed. I keep hearing different things over the last couple of days during my research.
Gary.
Gary.
- x 6945
No problems. I just hope this is the culprit. I should of said also to check the fuses - and when I say check the fuse - I don't mean a quick look to see if there is a break in the middle. These blade fuses can suffer from galvanic corrosion - if any of the metal legs covered by the plastic of the fuse look 'milky', change the fuse.
The following are located in the engine Fuse box located as shown (click to zoom).
F11 40 Amp - Front A/C Blower
F10 30 Amp - Multi Function Motor Control
- x 1940
I was at this stage when I popped it back in and it worked again - and still continues to work. It's got to be worth trying it back in first of all.crapday69 wrote: 02 Nov 2017, 12:07 I found it lol. How to I tell if its not working, is it just replace and see. I got it out, is there a way to open it up to see the gubbins inside.
crapday69
- (Donor 2017)
- x 59
I noticed that my battery is not fully charged and I read somewhere that this could be a cause, but then again when i'm driving at 70mph, that should generate enough power to the car.
I checked my alternator charge and its charging the batter fine.
I've got a new one coming tomorrow so i'll just wait as I don't want to keep squeezing into that tight space with my sore back lol.
Thanks all for the help. I was a member of the C4 website for years with my C4 (I won't name it incase it breaks rules) that was a good help. So far this site has been a good help too. I will try and do a few how to's when I maintain my car. I do an oil and filter change every 6 month. I did have a how to for the C4 fuel filter that should be similar for the C5 I think.
Gary.
Gary.
- x 5672
You are more than welcome to name other websites and forums - we don't exist in a vacuum or pretend others don't exist and others can provide much useful information.
crapday69
- (Donor 2017)
- x 59
I just plugged it in and left it dangling and then started the engine, still no luck. When I took the part out again it was warm, not hot but room tempish.
Gary.
Gary.
crapday69
- (Donor 2017)
- x 59
heater blower not working
Took my car for fuel and a wee run. Battery charging ok and fully charged, but a funny thing is happening, when I went to put one of my windows down a little with the ignition on (just turned on) the car was in power save mode to save the battery from draining. Their must be something draining the battery and therefore turning power save mode on. I have put my dehumidifier in the car to take any dampness out as its been lying in arnold clarks for past 2 weeks. I'll buy a battery charger and fully charge the batter I have in the garage and swap them over just in case its the battery thats not got enough charge in it.
I tried the BSI reset procedure to no avail either.
Gary.
Gary.
- x 6945
Gary, the economy mode will kick in to save battery and you will only get so much time added again based on the length of the previous run before the engine was switched off again. So an hour uninterrupted drive will give you UP TO 30 mins before it kicks in again. If charging on the car, and you have the battery charge status device attached to the negative terminal you need to ensure that the negative charging clamp is attached to the device and not the battery terminal.
crapday69
- (Donor 2017)
- x 59
Fitted the new blower control module that I got from ebay, the only problem now is that it only works on one setting. Thankfully it seems to be a low setting so i'm not too bothered at the moment as it will de-mist the windscreen.
Gary.
Gary.
crapday69
- (Donor 2017)
- x 59
Been driving quite happy this last week with the blower stuck on a low setting but I have noticed that when I start the car the blower is on high for a second before going back to the low setting. Might do another BSI reset to see if that might rectify this.
EDC5
- x 130
This seems like an odd fault. I'm guessing the blower control module is actually a PWM MOSFET module that takes a reading from the front panel air conditioning controls. If the new one isn't working then it suggests that it may not be receiving the correct signal to set the fan speed with.
