XANTIA BLOWER WORKING INTERMITTENTLY
- x 8391
Re: XANTIA BLOWER WORKING INTERMITTENTLY
Malcolm, excellent! Delighted this thread has helped you resolve a problem
daviemck2006
- x 485
Gabbys heating fan has been playing up a little, and refused to work at all tonight. A swift thump restored normal operation, so its likely the big brown plug is the culprit. I shall investigate in daylight.
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
Peugeot boxer 2016
In the family
- x 1996
Uggg.....my slider has decided not to go over to demist again....I fear a new cable will be needed this time (and some platers for my scratched hands)
aneesh84
- x 29
My Xantia blower sometimes stops working and I feel the most likely cause is bad contact at the 4 way brown plug. What is the best way to fix it? are these plugs available?CitroJim wrote: 28 Sep 2012, 16:24 Stewart, being a late S2, most of the common problems suffered by S1 Xantias in this respect do not apply![]()
A quick test. Does the blower start up if you 'jiggle' the blower speed control slider around the @AUTO' position? Sometimes it's just bad contacts on the blower slider.
Another very likely one is a bad connection where the 4-way brown plug plugs into the blower unit. The high current flow can cause the contacts to heat up and loose temper. Try disconnecting the plug and re-connecting it.
Do you have access to a multi-meter to assist in measuring voltages around the blower?
C5 2005 2.0 HDI 138
Nissan Leaf 2018 40Kwh
C5 2005 2.0 HDI 138
