Peugeot Partner 2.0 HDI Problems
Prokart
Unread post by Prokart »
Hi
My Peugeot Partner is having some issues recently.
On a cold start the idle is rough (revs keep fluctuating to 1100 rpm back to normal idle) but is fine once the engine is warm.
Also while stopped at traffic lights, if it is revved up it has a lot of rev hang and takes longer than it used to to return to idle.
The third issue is that under heavy acceleration there is a lot more black smoke than what would have originally been there.
Once warm, in normal conditions, most of these symptoms seem to go away.
Thanks for the help
Pro
x 1498
Re: Peugeot Partner 1.9 HDI Problems
Welcome Pro!
Not sure exactly what engine we are dealing with here? There was the old 1.9 DW8 indirect injection engine, then the 2.0 HDi common rail direct injection. No 1.9 HDi.... If you can post the last 8 digits of the VIN we can confirm the engine if you're unsure.
Prokart
RichardW wrote: 30 Oct 2017, 16:15 Welcome Pro!
It is the 2.0 HDi engine :-D , i will edit the post now to fix the error.
Prokart
Is there a way to check (and setup) about obd2 on the 2004 partner, i purchased a bluetooth obd2 adaptor but couldn't get it to work. I have done some research and I am going to try a few things tomorrow but I was wondering if obd2 is supported by the vehicle and if there is any options i should use for it (using the torque app)
