Which plugs?
Flynn
Which plugs?
Unread post by Flynn »
Wanted a new set of plugs for a BX16v. NGK list the type needed as BCP7ET but GSF only lists BCP7ES. Anyone advise what the last letter means, is it a temperature thing, and how much difference it makes?
Jon
Unread post by Jon »
The GSF N92726 should be BCP7ET, thats a 3 prong type plug. BCP7ES is single elctrode plug (used on BX 16v + Kat from memory)
Flynn
Thanks Jon. That part number isn't listed in the PDF catalogue afaics. But they will have it if I ask I take it?
Jon
Hi
Looks like there is some sort of supply problem on these plugs, and for that reason they were left out of the catalogue.
Just checked Group stock and there are about 40 BCP7ET plugs scattered across the Country at various branches, so GSF can still supply them for the moment.
Drop me a line and we'll find you a set, no problem.
