309 Rear Engine Mount
burns
Unread post by burns »
Right I'm thinking mine needs replacing, it's migrating out the side of its alloy mount and looking in a pretty sorry state. If I get one from GSF, is it going to be easy to fit? Some people seem to say it should just push in, others say it needs a press/vice. It seems you can't take the whole alloy block off without taking the driveshaft off so I'd rather not do this. So, if I order one from GSF am I going to find that I can't actually get it in and need to take it to a garage?
PowerLee
Unread post by PowerLee »
Sometimes they drop in easy, Other times the mount has to come off & the rubber pressed it.
If you do end up taking the mount off, The driveshaft has to be remove FIRST before undoing any of the mounts bolts.
They can be a right pain to do if its your first attempt at one.
burns
I'm struggling to hunt this part down, the dealers say it's only available with the whole bracket which the intermediate driveshaft goes through. The local GSF said they only had them listed for the 1.6 and 1.9 engines. Does anyone know if this is the right part? To clarify its the bit that goes in the alu section that bolts to the engine, not the mount at the subframe end. A GSF part number would be great, I'm not sure which one it is.
