Merged Lexia & Diagbox threads
- x 1943
Re: Merged Lexia & Diagbox threads
Do Easydiagnostics only sell full chip versions? They won't even supply the partial chip versions by request (even if the choice is accidental)?
KennyW
- x 165
Tried to run mine but when attempting a global test it was not recognising any of the ecu's.
In the past I did get some of the ecu's recognised with the fault codes but nothing now.
It does identify the car and obtains the VIN but I can't go any further.
Kenny
Kenny
C3 1.4 petrol (SWMBO)
- x 6957
That sounds like it has been deactivated Kenny!
Close down Diagbox. The try copying your original licence file (Appdiag.sys) back to C:\AWROOT\BIN\FI\
Overwrite the file when prompted and then try and relaunch the programme and try another global test.
KennyW
- x 165
Thanks Mark, Will give it a try tomorrow.
Kenny
Kenny
- x 6957
Worth a shot Kenny - all it takes is to go into an area where you need to record a Technician ID prior to making a change (for logging) and that is enough to deactivate the system - even if you don't proceed. Just cancelling the action can deactivate the whole system - reinstating the licence file usually solves this.
KennyW
- x 165
Marc,
It worked for my X7 but tried the C3 62 plate and I got to the global test which ran but did not recognise any of the ecu's.
I'm thinking I might need to reload diagbox again.
What do you think ?
Kenny
What do you think ?
Kenny
- x 6957
So that would be a 2012 / 2013 C3. What version of diagbox are you running Kenny?
- x 1943
And is your X7 older than the C3?
KennyW
- x 165
Running 7.57
X7 2010 & C3 62 plate
Kenny
Kenny
- x 6957
I would try an update to 7.58 Kenny. I’m out in town now but will send you a link to the update later if you want to give it a go just in case.
KennyW
- x 165
I've got the 2 discs from easy diagnostics so can upgrade to 7.58. Would it be worth going to 7.62 ?
Kenny
Kenny
- x 6957
I would stick to 7.58 first Kenny and test that out - the 7.58 version includes the addition of the "Test by ECU" function that I think Mike was referring to.
I've found I tend to stick with the version that works with my cars as further upgrades can also introduce more issues that are then resolved in much later updates....
KennyW
- x 165
Excellent Marc slowly but surely I'm learning the Lexia.
Soon I'll be able to confuse other people.
Just checked my discs and I don't have versions 7.58 or 7.62. IF you could provide the link later that would be handy.
Kenny
Kenny
KennyW
- x 165
Marc,
Can you send me the link to update Diagbox to v7.58. ?
Kenny
Kenny
- x 6957
I've sent you a PM Kenny
