Peugeot 207 Vti crank no start ongoing issue
max1
(Donor 2017)
x 5
Re: Peugeot 207 Vti crank no start ongoing issue
Unread post by max1 »
darbuck wrote: 13 Sep 2017, 17:53 Hi Mike can you put the link for that video up or pm me if you wish I am having a similar issue to Max wit a TPS IAC and knock sensor circuit as 3.3v but she still runs so maybe He can enlighten me to something I am missing
This is very interesting. I take it your ECU is a Bosch, same as mine?
Do you have any codes present with this 3.3v ? Any symptoms at all, like weird temp gauge readings ?
max1
(Donor 2017)
x 5
MikeT wrote: 14 Sep 2017, 13:53
darbuck wrote: 14 Sep 2017, 09:27 Mike from looking at those readouts it looks like the sensor itself is no good
I believe max tested the sensor and even replaced it which is the fault code you see but as the circuit (without sensor) was also tested as no good, that's where we're at.
ekjdm14 wrote: 14 Sep 2017, 10:24
Not quite, as I see it the ref voltage should always remain at 5v and the ECU takes it's readings through resistive sensors that pass a percentage of said voltage to ground through the ECU's measuring medium. The only time the ref voltage itself ought to vary from 5v is if there's either a short in said circuit that loads the driver beyond it's capability to maintain this steady voltage (likely in the wiring prior to the sensor input IMO) or if there's a faulty component providing the voltage.
Yeah, I get that but it's so frustrating I sought humour being flippant. I should know by now it never translates well, should have kept it to myself. :lol:
In this case I'm taking the fact that 2 separate ECUs have faults where a reference voltage has dropped to the same exact level within 0.1v to mean it's more likely than before that there's a common failure mode within the ECU's driver circuitry that causes this drop. That's not to say it isn't just a wiring fault, just that in my (inexpert!) opinion, the likelihood of faulty ECUs in both cases has gone up by a large percentage.
Before Darren's input (excuse the pun :-D ), I could find no other examples of a 3.3v signal input, in fact scannerdanner was the only place that came close, with reference voltages at either a lower 1.7v or 0v. Maybe my search methodolgy is lacking but that's all I found.
Also interestingly, many of the case studies scannerdanner uses are engine swaps (as with max's situation) with faults such as frayed rubbing or pulled looms, rotten earths and misconnected wires, faulty sensors as well as one case of reverse polarity when using a bluepoint professional charger - on booster mode - which made the battery explode! That DID fry the ECU.
Obviously, that's a way too small a sample to draw any meaninful conclusions from but scannerdanner has stated that symptoms of a failed 5v supply often equates to no comms with the diagnostic scanner too. i haven't found anything to confirm this though.
I think I made it clear way back when the ECU 5v pin measured 3.3v, I accept the ECU may well be at fault but since then we've got no closer to a definitive diagnosis leaving max facing even more expense he can ill-afford.
I searched high & low for 3.3v as well Mike, couldn't find anyone either.
max1
(Donor 2017)
x 5
I was on the verge of sending the ECU off today, I think ill hold off just a bit longer & see what the consensus is here first, but looking even more likely now.
MikeT
x 232
Unread post by MikeT »
max, if the ECU is still in-situ, I wouldn't mind the opportunity to carry out other scans and readings while you're waiting? I realise you're anxious to move forward and don't want to delay you further but if there's a chance to get more data, I'd like to see it.
max1
(Donor 2017)
x 5
Sure Mike, i am at home today. However the battery will possibly be getting pretty low by now, I'm don't know.
MikeT
x 232
max1 wrote: 14 Sep 2017, 14:55 Sure Mike, i am at home today. However the battery will possibly be getting pretty low by now, I'm don't know.
Thanks, will be over your way within the hour, hopefully.
ekjdm14
x 269
Unread post by ekjdm14 »
MikeT wrote: 14 Sep 2017, 13:53Yeah, I get that but it's so frustrating I sought humour being flippant. I should know by now it never translates well, should have kept it to myself. :lol:
no worries, I "got" that the sceptical kid was in humour just felt I needed to clarify why I was going further towards suspecting the ECU
Now, this is something I didn't know... I may be getting confused with other threads here but I'd swear that I read this car was running and just stopped? :? Now, if this is indeed an engine swap then I'd have to lean back toward a pinched/pulled wire or perhaps a couple of close components having their connectors swapped round. (on that last point, I know there's no other fault codes but does absolutely everything else on the car work perfectly as it ought to, headlamps/fogs/wipers/blowers and the like? I appreciate the AC is impossible to test with a non runner but just to rule out an accidental plug switching between components).
Definitely I'd be looking at the wiring like a hawk if its an engine swap though.
'96 ZX SX 1.9TD, White, 88k
'12 Mini freebie project
MikeT
x 232
ekjdm14 wrote: 14 Sep 2017, 15:07
No, you're right first time, it's an engine swap that has since been running (albeit with an "off" coolant temp display on the dash) but began having starting issues since. ie, max could get it to run when he disconnected the ECT but he didn't like the fan running full-speed. Next attempt, it wouldn't start at all.
ekjdm14
x 269
Ah, that's a strange one yes :? So rather than all being "rosy" from the get-go it's always had ECT issues (just since the swap? or did it have a problem here prior to the swap do we know? That'd make a difference to where the cause likely is).
If it's just been since the swap then I'd look to wiring either pinched or chafing (probably the latter given the car's "downhill spiral" of late) but again if the coolant gauge was iffy even before the engine swap then it'd point my eye toward the ECU again.
Actually, it may be relevant maybe not, but what was the reason for the original engine swap? possible clues there too?
MikeT
x 232
ekjdm14 wrote: 14 Sep 2017, 19:53 Ah, that's a strange one yes :? So rather than all being "rosy" from the get-go it's always had ECT issues (just since the swap? or did it have a problem here prior to the swap do we know? That'd make a difference to where the cause likely is).
I think the coolant reading fault was after the engine swap but best let max answer those historical questions before I cause more confusion. :oops:
ekjdm14
x 269
MikeT wrote: 14 Sep 2017, 20:03
Yes, I'll leave it for Max to come back on these bits of info as & when he has the time/inclination to think about sorting the car again. I can well understand if he needs to take a break from the thing now, knowing how frustrating it can be to spend good money and still be left with an unusable car. Just hoping we can get it sorted as I'm sure we both would like to see a positive outcome as well as Max.
max1
(Donor 2017)
x 5
ekjdm14 wrote: 14 Sep 2017, 20:10
Coolant problem appeared after the engine swap, down to the bad ECT sensor in the s/h engine leaking coolant. Engine was swapped because of intermittent blue/white exhaust smoke & loss of power, suspected piston rings or head gasket.
The current dilemma is working out why I have 3.3v & if any other sensor/wiring could pull down the voltage. Waiting to hear back from scannerdanner forum on this subject.
I am very interested in hearing back from @darbuck as he says he has 3.3v as well ! Am wondering how his car is working ok with an apparent 3.3v reference ?!
MikeT
x 232
Bosch MEV17.4 ECU http://www.actronics.eu/en/shop/peugeot ... ch-mev17-4
Diagnostic information
Engine temperature (too) high and cooling fan runs continuously
Fault on 5 volt circuit
Not the same symptoms so wonder if this^^^ is effect (of coolant ingress), rather than cause?
MikeT
x 232
Here's a claimed definitive diagnostic test I've not seen mentioned before.
http://www.searchautoparts.com/motorage ... akdown-pcm
Doing this reference voltage test requires measuring for both proper voltage level and current draw on the same wire at the same time as shown in Figure 1. We need both current and voltage to be measured to first determine whether the lack of 5V reference is due to the PCM not being able to output the proper voltage because of an internal defect. In this scenario, the voltage will be low and very little current will be flowing in that reference wire. On the other hand, if the proper voltage output from the PCM is being pulled low due to a shorted sensor or harness defect, the voltage still will be low, but too much current will be flowing in the wire. The current flow level in the wire is the key in determining which of these two defects is the true cause of the problem.
I guess the problem here is determining what a normal current draw should read and then having the test equipment to detect it?
ekjdm14
x 269
MikeT wrote: 15 Sep 2017, 14:16 Here's a claimed definitive diagnostic test I've not seen mentioned before.
Now THIS is a good idea, all we need now is somebody with the same car but running and who wouldn't mind measuring the current draw on their car. (I don't think we need to track the voltage at the same time in this case as we know it's staying at 3.3v on the subject car).
If a clamp type meter was used, there wouldn't even be any need to physically break into the circuit anywhere and AFAIK the current could be non-destructively measured where the wire leaves the ECU plug.
