C5 suspension
zeeshanzaki
- x 6
C5 suspension
I noticed couple of times that when the car was lowered after jack up, the suspension drops down to the lowest level. Then i have to wait for couple of minutes to raise them to normal height. I also see some oil on both front suspension. Is this normal behavior or something need to be fixed.
zeeshanzaki
- x 6
Re: C5 suspension
Also the fluid level is just below the low level. Will this cause any problems
- x 6955
Re: C5 suspension
When you say 'jacked up' how did you do this - if you raised the vehicle off the ground with wheels hanging, you should of first raised the car to the highest suspension setting before doing so and then removed the LDS cap before lifting it. When the car is then lowered to the ground, you can replace the cap and then lower the suspension back to normal.
The weight of the wheels hanging freely can cause pressure issues in the system that can cause leaks or even a burst LDS tank if not careful.
As for suspension fluid. This should be checked with the car suspension on the lowest setting, wait for 2-3 minutes and then check the level which should be between the points a & b shown:
As you haven't stated what C5 model you have the top one is for a C5 X7. This one is fot the C5 MK I and MK II: It is common for there to be a little oil on the strut near the top - like a damp patch - but it should not be leaking.
Unless there is a specific service operation / reason not to, the suspension should be raised to maximum before lifting or jacking the car, but as said, always raise to high and remove the LDS cap when any more than one wheel will be left hanging unsupported.
zeeshanzaki
- x 6
Re: C5 suspension
GiveMeABreak wrote: 11 Sep 2017, 10:21 When you say 'jacked up' how did you do this - if you raised the vehicle off the ground with wheels hanging, you should of first raised the car to the highest suspension setting before doing so and then removed the LDS cap before lifting it. When the car is then lowered to the ground, you can replace the cap and then lower the suspension back to normal.
Thanks Marc
Mine.is 2001 model.
The struts are lubricated and does nor drip fluid. So its not a problem.
I didn't know that car need to be raised before jacking up but now I will tell mechanic to follow the proper procedure.
This was only came to my notice when mechanic raised the car from driver side and dropped to the ground to prove that the suspensions are leaking and didn't want to pass. But after couple couple of minutes the car came to normal height.
Before that I changed all four tyres a month ago and didn't see suspension to the lowest setting.
So is this sign of something going to fail.
- x 3302
Re: C5 suspension
When I had the front tyres on my C5 MkI replaced I raised her to full height and loosened off the LDS cap (much to the amusement of the tyre fitters). Then, once the work was done, and they lowered the jacks, they were surprised to see her remain at full height. In their experience C5s have always bottomed out, and needed time to come back up to the normal height. They said they would try to remember that trick in the future, as it saves them having to wait to get their jacks back.
- x 6955
Re: C5 suspension
You should never drop the car back to the ground from a height - get a new mechanic it he didn't know that.zeeshanzaki wrote: 11 Sep 2017, 11:56
Thanks Marc
Mine.is 2001 model.
I'm not quite sure I understand your last point
- If you are changing the tyres and the car is being lifted completely off the ground and the wheels are not being supported by the hydraulic lift, then raise the car to highest suspension setting and remove LDS cap. The same applies if they are using a hydraulic lift supporting the car by the jacking points - it doesn't matter which method, but if the wheels are left hanging freely, that will cause pressure issues when returned to the ground if you don't follow the procedure I described before. I always make sure I am there when having tyres fitted, and raise the car and remove the cap myself. I don't trust them to do it properly and many don't even know about it.Before that I changed all four tyres a month ago and didn't see suspension to the lowest setting
Harlequin
- x 24
Re: C5 suspension
From the manual for my own mk 1 2002 C5 - for any jacking you need to set the suspension to HIGH
- x 6955
Re: C5 suspension
Yes,it's good advice in general Simon.
darbuck
- x 290
Re: C5 suspension
I knew about the height setting, but I was unaware of the need to remove the cap
I must remember that
, its true you learn something new every day . The amount of times I could have done damage it doesn't bear thinking about.
Darren
zeeshanzaki
- x 6
Re: C5 suspension
I want to top up LDS fluid as it is below low level. Is it easy and safe to top up?
I never drive the brand new Citroen so don't know how the new or properly working suspension performs, but mine are not bad. Does it cause any issue if I don't top top. Or is there any improvement in ride when maintaining fluid level?
There was a crack leak back pipe which might have reduced the fluid level but I fixed that issue. So there is no visible leaking apart from some oil in the suspension.
- x 3302
Re: C5 suspension
Assuming that the suspension is working properly it is easy and safe to top up the LDS fluid. Drop the car to her lowest setting, and then wait for a few minutes (this is to allow the LDS to settle down). Open up the LDS reservoir cap, and you will see a grill with some vertical slots. The slots show where the upper and lower fluid points are meant to be. top up the fluid so it is around the upper level marker. Pop the cap back on, and then check the car returns to the normal level correctly.
- x 6955
Re: C5 suspension
zeeshanzaki wrote: 20 Sep 2017, 02:36 I want to top up LDS fluid as it is below low level. Is it easy and safe to top up?
Look at the diagrams I posted above. Instructions are there, but again, make sure the suspension is on the lowest setting before checking and topping up otherwise you can overfill it and you don’t want to do that.
zeeshanzaki
- x 6
Re: C5 suspension
Thanks Marc
I will order LDS and top it up.
I noticed that ride is not as comfortable as it used be couple of month ago. I can feel the bumps when go over the rough road. So there is something happen during last few trips to mechanic. Also the normal height of suspension less than it used to be couple of month ago. I checked the car and there is no LDS leak, so could have cause the issue. Is there any other way to test the suspensions are working fine.
- x 6955
Re: C5 suspension
It might need bleeding if the system was a little low on LDS, so when you are checking the levels, follow this guidance to bleed / check levels:
- Start the engine.
- Wait for the vehicle height to stabilise.
- Place the suspension height control in the "HIGH" position.
- Place the suspension height control in the "LOW" position.
- Turn the steering from lock to lock in each direction.
- Stop the engine.
- Check the LDS fluid level
zeeshanzaki
- x 6
Re: C5 suspension
Do I need to this procedure after topping up fluid or before.
