Recently, I’ve noticed a sort of metallic creaking noise coming equally from both front wheel (or possibly underneath) whenever the car leans. Be it turning a corner, jiggling the wheel left and right whilst moving very slowly or even pushing the car side to side above the driver’s door.
On my old focus I had a similar problem that turned out to be anti-roll bar drop links, but that was definitely a banging noise not a creaking.
The car drives well, no steering issues (tracking was done recently)
Any ideas?
C5 X7 loud creaking from front both sides.
EDC5
- x 130
- x 2004
Re: C5 X7 loud creaking from front both sides.
If it does it (noticed at slow speed) then it is ?probably the lower Frap joints
https://www.frenchcarforum.co.uk/forum/ ... ower+joint
EDC5
- x 130
Just read that thread, looks like a bit of a job. Is that the most likely candidate for the source of the sound?
I'll just add that it's not steering side to side that causes the creak, it's the lean of the body that's doing it.
I'll try and get a recording of it as that might help.
- x 2004
Ah....the lean, so is the creaking coming from the strut or the lower area. The FRAP joints will make no noise when stationary.
EDC5
- x 130
It's difficult to tell to be honest, however it does come from both sides equally.
Do the anti-roll bars cause much trouble on C5's?
I'll get a video or a sound recording tomorrow and hopefully that will be a little more helpful.
- x 2004
The coating on anti roll bars breaks up allowing them to rust into the rubber mount for sure.....I nearly lost the rear one due to it.
demag
- x 102
Not sure of the X7 set up but I've known worn dry ball joints creak, ending in disastrous circumstances if not attended to.
Dave
EDC5
- x 130
As promised here is a video with the sound, the suspension is on normal, when I set it to med-high the sound is much more difficult to reproduce but that may be just because it's more difficult to rock the car.
Just a note, In the video (out of shot) I'm pushing the car horizontally at the top of the passengers side door.
Any ideas?
Any ideas?
- x 5675
That is very strange.
- x 1496
I'd be surprised if you don't find that is the lower 'frip' joints....
EDC5
- x 130
RichardW wrote: 10 Sep 2017, 21:21 I'd be surprised if you don't find that is the lower 'frip' joints....
Is that the thing that looks like a bear claw?
As show in this video?
I was thinking that it might be anti roll bar related as the sound is present on both sides equally. Would disconnecting the ARB drop links and repeating the push test be any good at eliminating the ARB as the source?
- x 2004
with the wheels on the ground if you can make the Frip joint move (horizontal) then it is worn no question. I would get a leaver bar in there and check before disconnecting stuff.........
EDC5
- x 130
Stickyfinger wrote: 10 Sep 2017, 22:20 with the wheels on the ground if you can make the Frip joint move (horizontal) then it is worn no question. I would get a leaver bar in there and check before disconnecting stuff.........
How do I check this exactly? By grabbing the top of the wheel and pushing in and out?
The car hasn't even done 60k yet, can they still fail at this relatively low mileage?
- x 1496
That's it. Have a look behind the wheel with it on full lock and see if there is rust around the joint.
Many are needing their second replacement by then - although there is a revised part that is better!EDC5 wrote: 10 Sep 2017, 22:29 The car hasn't even done 60k yet, can they still fail at this relatively low mileage?
It could be the ARB, but given the propensity of the lower joints to fail and create all sorts of odd noises, I'd go looking there first.
- x 2004
EDC5 wrote: 10 Sep 2017, 22:29Stickyfinger wrote: 10 Sep 2017, 22:20 with the wheels on the ground if you can make the Frip joint move (horizontal) then it is worn no question. I would get a leaver bar in there and check before disconnecting stuff.........
Yes: Part No 14
You can get a long flat lever bar in next to it....I used a crow bar and lever sideways on the hub to see if there is lateral movement, do the testing with the wheels on the ground with wheels turned.
