Clio gearbox whine
This is the Forum for all your Renault Technical Questions, Problems or Advice.
Teenagedimwit
Clio gearbox whine
Unread post by Teenagedimwit »
Hi, another fault I forgot to add to my previous post is that the gearbox seems to be whining when acceleration and deceleration. The Car has around 100k on the tranny and hasn't been used for 3 years. Do u think the bearings are worn out? Gear changes slightly higher than I remember.
x 1240
Re: Clio gearbox whine
Unread post by Peter.N. »
Noisy bearings can go on for years and are also expensive to replace, whining on acceleration and deceleration suggests it may be the diff bearings, in any event if its not unbearable I would put up with it. Do check the gearbox oil level though.
ferkemall
New User
Unread post by ferkemall »
When you done all of the above get under it and wiggle the drive shafts up and down if it has movement its the diff bearings !
ekjdm14
x 266
Unread post by ekjdm14 »
only 19 months too late... again...
'96 ZX SX 1.9TD, White, 88k
'12 Mini freebie project
