Hi, I've stumbled on this great site whilst looking for a VIN decoder. Could anyone help me please?
The VIN on my Renault Megane is VF1**************[VIN obfuscated, can be read by forum staff]
Many thanks
Ann
Deciphering a VIN
- x 6963
Re: Deciphering a VIN
Hi, I'm sorry but I don't have access to the Renault docs to help, you but a search using a web service has revealed the most basic of details:
Manufacturer: RENAULT SAS
Manufacturer Address: 13-15 Quai Alphonse Le Gallo, Boulogne, 92513 Billancourt Cedex
Product Type: Voitures Particulieres
Make: Renault
Model: Megane
Series: Megane II CC
Body: Cabriolet/Convertible
Drive: Front-wheel drive
Number of Seats: 4
Number of Doors: 2
Steering Type: Steering rack
Length (mm): 4355
Width (mm): 1777
Height (mm): 1420
Max Weight (kg): 1775
Minimum volume of Luggage (trunk): 190
Maximum volume of Luggage (trunk): 490
Track Front (mm): 1518
Track Rear (mm): 1514
Wheelbase (mm): 2522
Wheel Size: 205/55 R16
Front Breaks: Ventilated discs
Rear Breaks: Disc
Front Suspension: The depreciated rack
Rear Suspension: Torsion
Fuel Type - Primary: Gasoline
Fuel System: Multi-point injection
Fuel Capacity (l): 60
Fuel Consumption l/100km (Extra Urban): 5.7
Fuel Consumption l/100km (Urban): 9.1
Engine (full): 1.6 i 16V (110 Hp)
Engine Displacement (ccm): 1598
Engine Power (kW): 82
Engine RPM: 6000
Engine Cylinders: 4
Engine Cylinders Position: Inline
Engine Cylinder Bore: 79.5
Valves per Cylinder: 4
Valve Train: DOHC
Engine Position: Front, transversely
Engine Torque (Nm): 151
Engine Compression Ratio: 10
Engine Stroke: 80.5
Transmission: Manual/Standard
Number of Gears: 5
Max Speed (km/h): 195
Acceleration 0-100 km/h: 11.8
ABS: 1
Production Started: 2002
Production Stopped: 2008
Check Digit: H
Model Year: 2003
Plant Country: France
Sequential Number: 397514
Make: Renault
Model: Megane
Number of Seats: 4
Number of Doors: 2
Length (mm): 4355
Width (mm): 1777
Height (mm): 1420
Rear Breaks: Disc
Engine RPM: 6000
Engine Cylinders: 4
Valve Train: DOHC
Engine Stroke: 80.5
Number of Gears: 5
ABS: 1
Check Digit: H
Model Year: 2003
