My Xantia Estate gathers water under the rear seats. The car was previously owned by my father who also experienced similar problems. He is certain that the water is not coming in from underneath the car as he has ensured that all holes are sealed. He is adamant that the water is coming in from the rear door area. The seals all appear fine. There is also dampness underneath the boot carpet which would seem to suggest that the water is running underneath and gathering in the well under the back seats.
Apparently a garage has also attended to this in the past but obviously been unable to solve it. Anyone had similar problems; and how have you solved it?
Thanks for reading.
S M Kelly
Xantia Est - water under rear seats
allmond
S Kelly
alexx
Rich
Hi,
Check out the "shower curtain" inside the tailgate behind the trim panel, i believe this often becomes detached from the door but just requires sticking back into place.
Merry Christmas and a happy new year to everyone!!
Rich.<img src=icon_smile_big.gif border=0 align=middle><img src=icon_smile_approve.gif border=0 align=middle>
- x 1057
S Kelly
civvie
- x 20
I once had a problem with wet under the mat on my estate, I took it to the local cit garage and they said it it was some kind of mastic seal that had broken down on the tailgate, I think it was something to do with the rear window area where two metals were joined?
Anyway they redone the seal and everything was then ok, cost a bit though as they had to take out all the lining etc from the tailgate. You know one pound for the mastic and one hundred for the labour.
Its just an idea, no doubt someone with a more intimate knowledge of the tailgate could elaborate.
Good luck,
Steve
Good luck,
Steve
alexg
Rich and Civvie's posts above looks like a good bet to me - the plastic membrane behind the tailgate trim on estates has to be completely sealed - the lock lets water in when it rains, and it is supposed to run away outside the rubber trim onto the bumper through some holes in the bottom of the plastic tailgate. If the membrane isn't sealed it runs inside the car, soaks the foam under the load area mat and ends up under the rear seats. Took me several tries to find something that would stick it back sucessfully - ususal tape / silicon sealant didn't last very long.
Found 'bolted panel sealant' on a roll at a local car paint shop (http://www.leonardbrooks.demon.co.uk), this worked fine and is still in place several years on.. Drying out the foam is a real problem - took about a week to dry in the summer...weighs a ton when saturated
Rgds Alex G
Edited by - alexg on 28 Dec 2002 15:39:21
Rgds Alex G
S Kelly
Les Finnie
I had the same problem with my Xantia estate. I checked out all the problem areas and found none of them applied to my car. The problem seemed to be water filling up on top of the bumper under the tailgate, on my old BX this water escaped down holes in the corner of the bumper, no such thing on a Xantia. On closer examination I found the rubber sticks down between the bumper and the body of the car thus blocking the only escape route for the water. Answer!!! drill holes along the length of the bumper near the edge of the rubber; result the excess water drains down through the holes and not over the rubber into the boot.
