The driver's window regulator acting weird
darbuck
- x 290
Re: The crane from driver's window acting weird
did you try to disconnect the harness at the hinge just as the window reaches the top of its travel
Darren
TodiCroitor
- x 4
Yes, exactly!GiveMeABreak wrote: 29 Aug 2017, 19:27 Sorry, what do you mean 'crane'? I think it's getting lost in translation? Do you mean window regulator?
- x 5658
furriegurrie wrote: 29 Aug 2017, 20:11 I think the ts has replaced the whole window (lifting) mechanism, hence the translation "crane"...
That was my take on it too.
- x 6955
Ok, I still think it is the anti- pinch protection. It looks like it is encountering some resistance and activating the anti-pinch.
I would double check you have aligned everything properly and make sure nothing is rubbing or catching on the channels. You should apply some grease to the regulator cables, and I would spray some silicon spray inside each of the window channels and work the windows up and down.
Ultimately this is a safety feature, and there must be some resistance to make it reverse.
TodiCroitor
- x 4
My Take ia that he doesn't know where to stop. I've tested the window regulator before fitting and it worked properly. After fitting I've taked a look inside and every thing seems fine I couldn't find anything that could prevent the window to close properly.
Also keep in mind that the windows is closing every time all the way up until the end but the window regulator tries to go further and only then I have this problem. There is no problem lifting the window all the way up, it goes smoothly.
- x 6955
Ok, well the only thing I can think of now is to remove power from the car and reset the ECU.
Let the window go down, open the bonnet and close all the doors and boot.
Leave the car 10 minutes.
Disconnect the negative terminal and leave it for 15 minutes.
Then connect it back up and leave it for another 5 minutes.
Reach into the car without opening door, switch ignition on but don't start.
Hold lock button on key fob down for 5 to 10 secs, switch off ignition.
Lock car with fob
Unlock with fob
Open car and start her up.
Now try the window reinitialisation again.
See if this fixes it.
Lock car with fob
Unlock with fob
TodiCroitor
- x 4
GiveMeABreak wrote: 29 Aug 2017, 21:46 Ok, well the only thing I can think of now is to remove power from the car and reset the ECU.
Lock car with fob
Unlock with fob
Did it and Wien I reached the part when I have to pull up the window and holding it there for a few secs I got the same result.
Reason: YouTube link
- x 1988
Re: The driver's window regulator acting weird
I note from that you are HOLDING the window switch down (it will try to auto close)
.......Tap the switch till it gets to the top a little at a time.....then HOLD it UP for 10 secs, then Hold the switch Down (then hold for 10 secs) then HOLD back up again and hold for 10 secs..
TodiCroitor
- x 4
Stickyfinger wrote: 30 Aug 2017, 11:35 I note from that you are HOLDING the window switch down (it will try to auto close)
I did that many times with the same outcome.
- x 6955
Ok, from your last video, I can definitely hear a straining noise from the window, like a squeaking noise - especially when it goes down, so it must be very tight or out of alignment at some point. That is very likely what is causing the anti pinch to kick in every time. Until you find out why it is too tight, this problem will remain I think. There isn't another solution until you have corrected it as the motors are designed to reverse as a safety feature. There is no other recalibration you can do, or any other settings to change listed on the documents.
TodiCroitor
- x 4
Even so this doesn't explain the fact that once the window reaches his top position and I pull one more time the button up, the window regulator brings automatically the window down. There is no more space for the window to go up, that would be the final position so why is he going down?
elma
- x 287
It's a safety feature.
If the window has to push against resistance it will lower.
This is so it doesn't trap fingers etc.
You need to remove the crane and reinstall it.
It's probably just slightly wonky.
Because of that the window is sticking a bit and automatically lowering as it can't tell the difference between trapped fingers and stickiness.
- x 2941
elma wrote: 30 Aug 2017, 13:03 It's a safety feature.
How does that translate?
- x 1988
Gibbo2286 wrote: 30 Aug 2017, 14:12elma wrote: 30 Aug 2017, 13:03 It's a safety feature.
How does that translate?![]()
slightly wonky = U?or r?t?cit....and back again = Easily lost
So, it does NOT translate well
slightly wonky = Out of alignment = Din aliniere
TodiCroitor
- x 4
some of you guys don't pay attention. what resistance are you guys talking about since the windows goes ALL THE WAY UP until there is no room for the window to go, that's the end point.
I know about that safety feature, everyone knows about it but this is not the case. For a "n" time - the window closes as expected but it seems that wants to go further more but there is free space to do that.
