Helpppp!!! No communication with suspension ECU
darbuck
- x 290
Hi lads I have been very busy on the C5 lately and finally got her running with no smoke woo hoo.
, BUT, running scan with dislexia discovered no communication with suspension ECU I checked fuses but cant find anything wrong is there any relays I should be checking its a c5 2.0 hdi 8V 2003 estate. Any suggestions
I need to access ecu to check settings
Darren
- x 1055
Re: Helpppp!!! No communication with suspension ECU
Is the suspension working as it should apart from no communication ?
darbuck
- x 290
Hi wheeler its up off its wheels at the moment but I tried using it and I cant hear the pump running I got my daughter to press buttons in both directions and and it doesn't move and I cant hear pump so I can definitley say no its not working now. it was working before the engine out but there was no comms with the suspension ecu at that stage either. Thanks for the reply by the way.
Darren
Darren
Darren
dnsey
- x 19
If the wheels are hanging, the ECU will think that the suspension's on 'high' already, so there's no need to run the pump. If you tell it to lower the suspension, it will open the valves to do so, but of course nothing else will happen.
IME, random lack of communication with various ECUs is pretty much par for the course with copy Lexias, and nothing to worry about in itself.
darbuck
- x 290
okay dnsey hopefully that is the case I will be doing brake bleeding and greasing pins tomorrow then I can put her back on her wheels. my lexia is normally fairly reliable that is why I am concerned, anyway I will post back result when I put her back on her feet.
Darren
darbuck
- x 290
Hi lads, I got the suspension going again, I unplugged and plugged back in the cables (have you tried turning it on and off again)
but , no comms with ecu still.
Darren
- x 3281
I wonder if a full BSi reset would help (or, potentially, hinder) the comms?
darbuck
- x 290
How are you doing Hell Razor long time no chat yeah I will give it a go it might work. The turbo I bought off ebay was over 30 days so no return
so now i am stuck with two duds.
. I really want to put her back on the road but it just seems to be begging for retirement.
Darren
lexi
- x 134
That is a shame. I wish you had put some pics up with engine out etc. What about trying a Chinese cartridge on a turbo?
Don't know what I would do if mine went. It is when you do so many other things to them that they are hard to scrap.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
darbuck
- x 290
yep I will just try and source a different used turbo the chinese cartridges have a terrible reputation i am afraid to try one incase it destroys the engine I cant afford to buy a different banger so this car will have to learn to behave
The engine has been out before and probably will again (hopefully not) I bought a bigger jack to raise her past the paunch to avoid removing engine in the future. I keep meaning to do wiki's for stuff I do but keep forgetting to take pics.
Darren
