Eolys?
taffy
Re: Eolys?
Unread post by taffy »
its totallyempty its just ive spent a fortune onit latley as it hasnt been serviced 23000 milesand was trying to save lol
06 silver 1.6 hdi vtr c5
08 black C4 GP 2.0hdi vtr
x 1943
Re: Eolys?
Even if you could get away with putting diesel in the Eolys tank I doubt very much you could get anywhere near a year before the filter needed cleaning out.
The Eolys allows the DPF to burn off the accumulated soot particles at a lower temperature than other systems which don't use Eolys (VW, Ford Vauxhall, etc) so I'm not at all sure that any burning off would happen (if you do decide to do this I'd love to know). If there's no burning off the DPF would fill up very soon - possibly a matter of weeks if you cover high mileages,
x 1943
Re: Eolys?
Just seen your second post - if the tank is totally empty the Eolys pump may now be knackered if it's been trying to pump non-existent fluid.
taffy
Re: Eolys?
just waiting for new turbo to come gonna wash dpf il tell u how bad Eolys warning sice baught car 6000 miles ago
x 1943
Re: Eolys?
I'm amazed the car was even driveable.
taffy
Re: Eolys?
its not really but spent all lastweekend cleaning the engine out of sludge its lucky to still be alive! i just gotta get to work :(
cachaciero
x 9
Re: Eolys?
Unread post by cachaciero »
taffy wrote: 19 Aug 2017, 19:27 as im skint etc and as the pat fluid is mixed with the fueland not into dpf could i not just fill Eolys tank with good diesil and just pop off dpf anually and pressure wash?
In a word no!
Without the additive the carbon produced by the engine will be harder to burn and build up faster. I also suspect that it will also be harder to blast out with a pressure washer, might require burning out. You may also find that the "variable geometry " bits of the turbo also seize up due to the kind of carbon produced.
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
urzica
Re: Eolys?
Unread post by urzica »
Hello, you can help me in determining the type of additive used in my car. According to my RPO No. 11126, IOL says that the EOLYS 176 is used, but the hose connectors in the tank should be green, but I have the white color that corresponds to the type of additive DPX 42 and not i know what to believe ????
The car is CITROEN C5 HDI since 2007, 1997 cc
Thank you.
urzica
Re: Eolys?
haydent wrote: 16 Jan 2015, 10:26 just posting my confusion here as well to contact subscribers to this thread, have rp in the 10,000's which would suggest 176 yet the connectors are white which suggests dpx ... 06 c5 ??
Same dilema with me...
x 6957
Re: Eolys?
I'll have a check for you in a second or 2
x 6957
Re: Eolys?
Ok, so this isn't going to be much help, as no blue or green click fit would seem to indicate that it is EOLYS DPX42 that you need. Because this additive can't be mixed with any of the others, I won't suggest one of the later replacement types. You are correct about the RPO - but the notes are quite clear - no green or blue click-fit, then DPX42.
So the best option is to double check with the main dealer and see what they say if you tell them that you have a white click fit and see what they say.
I know it doesn't help much - the whole additive area is a disgraceful state of affairs for a company like PSA who invented the damned DPF! The advice (if you can call it that) is very unclear.
urzica
Re: Eolys?
GiveMeABreak wrote: 19 Sep 2017, 20:59 Ok, so this isn't going to be much help, as no blue or green click fit would seem to indicate that it is EOLYS DPX42 that you need. Because this additive can't be mixed with any of the others, I won't suggest one of the later replacement types. You are correct about the RPO - but I the notes are quite clear - no green or blue click-fit, then DPX42.
Thank you1
Xantippa
x 29
Re: Eolys?
Unread post by Xantippa »
C5 HDi 240 says additive level too low. Is there a guide how to fill up for C5 X7 if I order eolys (176?) from ebay? I've got diagbox so I can reset eolys counter.
cachaciero
x 9
Re: Eolys?
Actually there is a way of determining which fluid to use. The firmware level of the engine ecu changed with the introduction of 176 the part number of the EOLYS injection computer also changed. So if you have a Lexia checking firmware should be a doddle, visual inspection for part number of the EOLYS ECU should'nt be too difficult. Now I no longer have a C5 and the info I need is not to hand, however I suspect that Marc (Givemeabreak) might be able to extract the details from the relevant Infodiags date some where between 2001 2005which was as I remember where I saw it..
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
x 6957
Re: Eolys?
He has an X7 Tony and these are quite different to the older MKI and some MKII systems.
For the correct fluid, either check the click fit connector colour, or check with the dealer with your VIN. Then order the filling kit and instructions should be included, but fairly simple.
Access from rear left wheel arch, after removing cover.
Gravity feed with overfill bottle. Just make sure you wear goggles and some latex gloves as the additive is not very pleasant.
The you should find the relevant option in either the repair menu or the engine ECU configuration options to reset the counter. There should be one there to add or top up additive fluid. Just follow the instructions exactly.
