406 clutch stiff
lesnajair
406 clutch stiff
Unread post by lesnajair »
Hi
As above 1.9LXS TD estate. Clutch seems very heavy compared to other peugeots and citroens with the same engine that I've drivn in the past.
Is there anything that I should concentrate on when I investigate?
Les
Plodder
Unread post by Plodder »
Just fitted a new cable to mine - made a hell of a difference to the clutch weight....
b21playa
Unread post by b21playa »
its the cable that causes it
change the cable and you should see a difference
but eventually it will do hard again
lesnajair
Thanks guys!
Les
