Windscreen with sensors
x 6956
Re: Windscreen with sensors
Post by GiveMeABreak »
What is your VIN?
doctle
x 226
Post by doctle »
GiveMeABreak wrote: 03 Aug 2017, 10:39 What is your VIN?
Oh buggle
x 6956
Ok, so you have the 307 5 Door Saloon 1.4 HDi 70 Manual 5 Speed
This is the windscreen that has the markings for the multifunction sensor, but does not contain the sensor itself.
The Multi Function Sensor itself (15), the Rain Detection Sensor Cover (16) and the Rain Sensor Support Cover (17) are separate parts, so the replacement windscreen will have nothing to do with the sensors - possibly just the pre-marking for mounting them.
So regardless of the windscreen, you should just fit the sensors back in place and deactivate the function if you do not want to use it. If you want to turn the function on or off (without PP2000) just follow this to deactivate auto lights:
To disarm or activate the function:
  • Place the key in the accessories position (1st notch),
  • Place the lights stalk in the AUTO/0 position,
  • Press the end of the lights stalk for more than four seconds.
Regarding your Fog Lights: For UK law, the front fog lights are not tested under section 1.3 (May 2017)
There must be at least one working fog light at the rear (either centrally or the offside).
doctle
x 226
Post by doctle »
Thanks a lot for the info I'm getting a new windscreen next week, car is ready for the world now!
Oh buggle
x 5586
Post by myglaren »
There may be an option in the BSI to have your dipped headlight come on with ignition on/engine running.
It is there for Scandinavian countries for the C5 I believe.
x 6956
That's quite correct Steve - another solution.
doctle
x 226
Post by doctle »
myglaren wrote: 03 Aug 2017, 18:57 There may be an option in the BSI to have your dipped headlight come on with ignition on/engine running.
How do I do this? The BSI seems to control a lot of things, if I mess it up will I have an expensive paperweight?
Oh buggle
x 6956
Yes is the answer, so caution is required when telecoding. You'll need somebody with Diagbox and Peugeot Planet 2000 to alter the lighting settings.
doctle
x 226
Post by doctle »
GiveMeABreak wrote: 03 Aug 2017, 11:46 Ok, so you have the 307 5 Door Saloon 1.4 HDi 70 Manual 5 Speed
I just checked the rules for the Irish National Car Test (NCT) no mention of front fog lights which is fine for the test. I'd kinda like to have them working there's power both sides of the front fog fuse on the BSI the little light on the dash comes on but no power to the bulbs.
Oh buggle
doctle
x 226
Post by doctle »
GiveMeABreak wrote: 03 Aug 2017, 21:32 Yes is the answer, so caution is required when telecoding. You'll need somebody with Diagbox and Peugeot Planet 2000 to alter the lighting settings.
I'll maybe just leave it alone I think there's a problem with the fogs on the BSI and I don't have diagbox or planet and even if I had I wouldn't have a clue how to use them!
Oh buggle
doctle
x 226
Post by doctle »
So does the sensor mirror fit the non sensor windscreen? I have an argument ongoing with axa insurance, the company "policy" which isn't in the insurance policy, is to have windows examined unless you have the car for an unspecified period of time. Seems they usually say it's an old crack and refuse payment. They use autoglass for the inspections and they commence the hard sell almost immediately, grrr. I'm going to have to bite the bullet and pay for it myself and the non sensor glass is considerably cheaper. BTW new bulbs and the fogs started to work, old bulbs works off a battery I got confused and left it at that!
Oh buggle
x 5586
Post by myglaren »
Try some other independent screen fitters.
Daughter's SAAB needed a new screen and SAAB wanted £1,000 or £800 cash :shock:
Autoglass wanted £600.
A small local firm did it for £129 and gave her a receipt for £300 :) *
*Her boyfriend at the time (and that was the finish of him) hit it and cracked it - he got to pay the £300 or appear in court.
She knocked his teeth out for good measure as he had tried to keep her imprisoned in his house.:)
x 3277
Post by Hell Razor5543 »
Sounds like your daughter is quite the character, with a strong will (and stronger punch!).
x 5586
Post by myglaren »
Hell Razor5543 wrote: 24 Aug 2017, 17:52 Sounds like your daughter is quite the character, with a strong will (and stronger punch!).
She was beaten up when she was 13 and said she would never let that happen to her again.
She is very sweet and as nice as ninepence until someone gives her grief then they get it back in spades. She is exceptionally fast and MMA :)
And a little squirt :) :)
doctle
x 226
Post by doctle »
Your daughter sounds like a feisty brave lady, more power to her, local firm is doing the windscreen for €190.00 cash, axa being the worst insurer ever wont pay, cest la vie. I rang a few companies they were all more expensive and some would only fit a sensor screen despite me telling them I was sufficiently sentient to know when it was dark or raining
Oh buggle
