Hello,
I´m rebuilding a 1.9 XUD9 Diesel and need some parts, anyone knows where can i get it?
I´m looking for the usual rebuild parts, pistons, rings, but i need specifically the turbulence chamber(Chambres de Turbulence). I´m living on South America, but i´m in Europe every 6 months, so it´s easy to me get some parts from Europe. Thanks for any help.
Thanks in advanced
Peugeot XUD9 parts
Oldpug
- x 94
Re: Peugeot XUD9 parts
The guy for old Peugeot parts in the UK is Dean Hunter http://www.peugeotparts.co.uk/
in France www.serie04.com
in Germany https://www.franzose.de/en/Peugeot/
ekjdm14
- x 265
Excuse my inexperience, but what exactly is the turbulence chamber? From searching online the closest I can gather is it's either the "comet" pre-chamber for the cylinder head or an external part.
Have you got a photo so I can see what it is, if it's part of the inlet or exhaust manifold then I probably have a used one you could have if you get to the UK at all. If it is the pre-chamber, I'd say it probably made more sense to get a replacement head without issues in this area as they don't generally give trouble.
Apologies if I'm way off the mark...
'96 ZX SX 1.9TD, White, 88k
'12 Mini freebie project
elma
- x 284
I think that they are what I know as the swirl chambers.
They are spherical inserts in the cylinder head.
The engine has indirect injection as the diesel is injected into these chambers and then makes it's way into the combustion area.
They are known to crack and pit over the years but it's not something thats affected me yet over 10+ Xud9s.
As far as I'm aware they need changing at the same time as the head is skimmed and it's not a diy / home job.
There was a guy near Chester (North West England) who offered this service but I cannot find him on google right now, not sure if he's still in business or not.
ekjdm14
- x 265
I wasn't aware of the need to change on skimming the head, only that there is a spec for how far they are allowed to protrude from the face of the head. Again I only have experience of stripping one XUD9 but none of the others I've owned have had any issues in this area either (the one I did strip was comprehensively blown up but the chambers all appeared fine on that).
elma
- x 284
ekjdm14 wrote: 30 Jul 2017, 12:30 I wasn't aware of the need to change on skimming the head, only that there is a spec for how far they are allowed to protrude from the face of the head.
I could be wrong Dan but thats how I recall it.
Mine ended up not needing doing and I last looked at this about 10 years ago.
I'm not saying that if the head is skimmed they need changing.
I was saying that if they are changed then the head needs skimming.
ekjdm14
- x 265
elma wrote: 30 Jul 2017, 12:45....I'm not saying that if the head is skimmed they need changing.
Aha, that makes sense yes. I read it as the other way round
elma
- x 284
In fairness I don't think I wrote it very clearly the first time.
- x 8417
Often the pre-chambers don't need changing for a light skim but they do have a habit of cracking across the orifice into the main combustion chamber and if they crack too badly they then don't work as effectively...
Dan, for more about them look up any articles you can find on the Ricardo Comet. The XUD pre-chambers are of that pattern as the XUD was designed by Ricardo - so in effect it is a British engine
