Merged Lexia & Diagbox threads
MikeT
x 232
Re: Merged Lexia & Diagbox threads
Unread post by MikeT »
Given my engine's sensitivity to oil hygene, I note my service counter is set at 12,000miles and therefore pretty much redundant as it's serviced well within that mileage.
However, I came across what I believe is a configurable setting for this in Lexia, though it was set to 19,200km (11930.327miles). Would there be any harm in changing this to say 10,000miles (16093km) or even 5000miles (8046km) as a safety net?
EDC5
x 130
Unread post by EDC5 »
MikeT wrote: 23 Jul 2017, 17:46 Given my engine's sensitivity to oil hygene, I note my service counter is set at 12,000miles and therefore pretty much redundant as it's serviced well within that mileage.
Whereabouts did you find that setting?, mine is set to 20,000 miles!, I'd much prefer a 10,000 setting myself :)
x 5672
If it is anything like mine it can be set on the dash during the reset countdown phase - mine is set to 6000 miles but will be done before it gets anywhere near that.
MikeT
x 232
EDC5 wrote: 23 Jul 2017, 17:53 Whereabouts did you find that setting?, mine is set to 20,000 miles!, I'd much prefer a 10,000 setting myself :)
Search me! Think it was one of the many, many BSI sub-menu's. I'll make a note exactly where.... if there's a next time I come across it. :?
MikeT
x 232
myglaren wrote: 23 Jul 2017, 17:56 If it is anything like mine it can be set on the dash during the reset countdown phase - mine is set to 6000 miles but will be done before it gets anywhere near that.
I didn't know that! The handbook just says you can reset it to "0" and that a dealer can change/reduce it if used under harsh conditions.
x 5672
Your newer on may be different but on mine the reset button counts down to a reset level of zero which equates to 12,500 miles.
I stop it at "1" which is 6,000 miles.
MikeT
x 232
I'll try that next time, Steve. If it works, I'll see if I can find that lexia page and see if it's recaclulated it to km's.
x 6945
MikeT wrote: 23 Jul 2017, 17:57
I posted this response on the RD4 thread by mistake!
viewtopic.php?f=44&t=58227&start=15#p543440
Anyway, there is the servicing schedule plan that is usually set up in the customer options.
x 1940
I was under the impression that if you didn't allow the countdown to go all the way to zero (and then a few seconds more) then the reset didn't happen at all. Maybe it's different of a few models?
x 5672
Couldn't say but I presumed there was an option to stop it for different environments.
Works on mine anyway.
Eddie Nuff
New User
x 32
Lexia 3 discs corrupted
Unread post by Eddie Nuff »
I tried to install Lexia onto a laptop for my brother but some of the files were missing. My son-in-law works in IT so he checked the disc over and found that these files had just disappeared. Don't ask why, he doesn't understand neither as the last time they were used was to install onto my laptop.
So can anyone make me a copy of the discs? A suitable donation to your favourite charity would be only right and proper.
x 2938
GiveMeABreak wrote: 05 Jul 2017, 17:43 Put anything in the top and scary01 on the bottom - see if that does it.
Finally got around to trying this, it didn't work, any other ideas?
tich731
Re: Lexia 3 discs corrupted
Unread post by tich731 »
I also have a requirement for a copy of Lexia 3.
I wish to instal it on a Netbook but have found the original disc to be physically cracked.
Anyone able to do a copy?
2009 C6 2.2 Hdi Exclusive Gris Fulminator
1999 XM 2.0 TCT Balmoral Blue Nacre
1987 2CV6 Rouge Vallelunga
1979 2CV Fourgonette (by Villevans) Cormoran Gris
1981 Midas Silver
1972 D Special Black (gone but not forgotten)
x 6945
Eddie Nuff wrote: 03 Aug 2017, 06:33 I tried to install Lexia onto a laptop for my brother but some of the files were missing. My son-in-law works in IT so he checked the disc over and found that these files had just disappeared. Don't ask why, he doesn't understand neither as the last time they were used was to install onto my laptop.
tich731 wrote: 05 Aug 2017, 15:08 I also have a requirement for a copy of Lexia 3.
I've sent you both a PM
leithant
x 9
Unread post by leithant »
Hi There folks, does anyone know if the usb connector on a Lexia is something that can be bought separately? Mine is damaged so I was looking for a replacement. There are VGA to USB leads that look the same , but I don't know if the wiring would be the same.
Thanks.
06 Citroen C5 Estate 2.2 Hdi Auto
95 Peugeot 306 S16
95 Silver Xantia VSX - now deceased :-(
