Hi all. I have a 206 SW 1.4HDI which has developed an issue when idling with the car at operating temperature.
The revs dip and it's like it's trying to stall but the engine stops itself stalling. This only occurs when the engine is hot.
When this happens there is a sound toward the left of the engine bay like it's sucking in air and then it escapes quickly.
When monitored on the torque obd app the vac readings go wild when it happens from around -1 to -16 fluctuating constantly.
My initial thought was either vac leak or egr but I found that when this happens if I unplug the air intake temper sensor it stops immediately and idles correctly. Plug the sensor back in and it's back to erratic. Could it be as simple as a faulty sensor or is this just triggering the real problem?
Here is a quick video:
Any ideas?
206 sw 1.4 hdi idle problem
dittohead
Reason: YouTube tags
- x 1485
Re: 206 sw 1.4 hdi idle problem
Welcome!!
Seems a bit odd - you really need to get it on Diagbox so you can see live data, it sounds like it is cycling something. Whereabouts in Scotland are you?
dittohead
Cheers mate. Am in Fife/Dundee area. Am tempted to try a new temp sensor as it's only about a tenner.
abbas10
- New User
did you find a solution ? i have same problem
- x 1938
dittohead last visited the forum on Thursday Aug 3rd, 2017 at 7:05 pm so you may not receive a reply I'm afraid.
