CITROEN C5 2.0 HDI BAV 138HP CONSUMPTION
EDC5
x 130
Re: CITROEN C5 2.0 HDI BAV 138HP CONSUMPTION
Unread post by EDC5 »
centurus2400 wrote: 19 Jul 2017, 14:02 The guy came out to my house in a very well equipped van.
The existing map was downloaded, then sent back to HQ.
About 20 minutes later a modified map was sent back to the technician, which was then loaded back onto the ECU.
As I said, it has made a very noticeable difference, and I have no complaints :-)
Ok, which map did you have uploaded and roughly how much was it? if you don't mind sharing that is.
x 6955
These were the people I contacted at the time when considering a tune - Angel Tuning: For mine and EDC5's car it would be £275, done at the Oxfordshire Centre - they do a full check and a road test pre and post remapping:
http://www.angeltuning.co.uk/engine-remap/citroen/
They do a £100 discount for 2 cars done at the same time. They can come out to you at a 25p per mile surcharge from their base.
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
hmm a discount..
could take the boxer, anyone else want in? ;)
EDC5
x 130
GiveMeABreak wrote: 19 Jul 2017, 14:13
Any reason you mentioned this Marc ...... 8-)
EDC5
x 130
jgra1 wrote: 19 Jul 2017, 14:32 hmm a discount..
Very tempting haha.
Out of interest, what sort of economy do you get in your X7 160?
x 6955
So for our cars it would be £225 a pop Elis, but if I decide to get it done, it will be after the age related timing belt and water pump service due next year ish 😁.
But I'd be very interested to get some X7 owner feedback from anyone having it done at Angel.
jgra1
(Donor 2021)
x 36
I dont know ED lol
she sits outside unused for the last 3 months.. I have just insured her and have the dreaded handbrake (I mean) Mot test on Friday at 11..
from distant memory :
I think I used to get around 55 to 60 mpg at best, averaging 60 -65 on the motorway.
I have seen her in single figures once or twice lol.. I imagine the average for me and these roads, is around 45
EDC5
x 130
GiveMeABreak wrote: 19 Jul 2017, 15:01 So for our cars it would be £225 a pop Elis, but if I decide to get it done, it will be after the age related timing belt and water pump service due next year ish 😁.
£225 doesn't seem too bad, but Ideally, I'd like to have a before and after dyno run too.
Same!, as we've discussed before I've got the cambelt to change at some point in the next year too, so I'm in no hurry.
Would be good to hear feedback, especially to check if the economy isn't ruined or that it doesn't lead to the rapid clogging of the DPF.
jgra1: Wow, that is actually better than I get at the moment.... seems like a win-win situation. Does it play nicely with your autobox? my concern is that a remap will be different to the gear change map and lead to erratic changes and other niggles.
x 6955
I think it will be a matter of adjusting to the higher power / torque availability post-remap. On the 'Economy' tune it is supposed to provide smoother power / torque across the range, so a 'lighter' touch on the gas I would suspect, as opposed to warp factor 9. :shock:
EDC5
x 130
GiveMeABreak wrote: 19 Jul 2017, 15:25 I think it will be a matter of adjusting to the higher power / torque availability post-remap. On the 'Economy' tune it is supposed to provide smoother power / torque across the range, so a 'lighter' touch on the gas I would suspect, as opposed to warp factor 9. :shock:
I'm wondering if the gearbox is the one that will need to do the adjusting since that responsibility is delegated in my car :rofl2:
Just a possibility, on Diagbox there is a parameter that the gearbox measures called "requested engine torque" and also "actual engine torque" or words to that effect. Hopefully a remap would be configured in such a way to provide the updated figures to the gearbox so that it can make the correct decisions... unless the engine torque is actually measured somehow?
Either way I'm sure I am worrying over nothing.
Personally, I wouldn’t want to sacrifice the economy any further but it seems that both economy and power can be improved at the same time so you'd be daft no to :P
jgra1
(Donor 2021)
x 36
ahh mine is just standard
cachaciero
x 9
Unread post by cachaciero »
EDC5 wrote: 19 Jul 2017, 15:37
Requested engine torque is as I remember derived from the throttle pedal, actual engine torque? not sure don't recall any sensor in the gearbox that could actually measure torque though I guess it could be derived from RPM making certain assumptions.but I think that would be part of the engine ECU calculation i.e there would be a map of engine revs to torque
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
jgra1
(Donor 2021)
x 36
16% handbrake...pass is 16% :evil: :twisted:
as usual the tester couldn't seem to operate second stage handbrake.. I didn't see if the rollers were moving when he was trying!? maybe you can't get that stage working if the wheels are rotating.. I watched him pull lever once..then again and hold..nothing.. worked for me last night though (stationary)
also had to rush and get her a new batt last night.. £92
another year ..always a nervous mot, an x7 ..
despite not driving it for 3 months I got little satisfaction being back in it..handling still seems unusual to me
cachaciero
x 9
jgra1 wrote: 21 Jul 2017, 13:54 [
Getting ready to move it on then :-)
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
jgra1
(Donor 2021)
x 36
I was tony. .. but have just insured it for business use and taken some dreadful job near Gatwick.. shift working :(
its an ideal use for the car.. ferrying me around at all hours ;) I may even use some of the fancy features like the phone and so on..
I want to investigate my suspension more now and the gearbox speed sensor .. it could just be that the x7 is heavy and I am expecting it to behave like a xantia in sport mode on the twisties..
