Thermostat:
- I've tested and replaced the thermostat: boiled it in a pan and it definitely opens and closes as it should
- With the engine warm-but-not-hot I disconnected the pipe at the thermostat housing that leads to the top of the radiator. There was a slight trickle coming from the thermostat
- I've filled the radiator by pouring water into the expansion tank until coolant came out of the same pipe. I then reconnected to the thermostat housing
I then took it for a blast (as much as you can take a DW8 for a blast) up a hill to ensure the engine was hot.
I disconnected that pipe, and coolant gushed out from the thermostat housing. The burns on my hand demostrate that the coolant was definitely hot and was flowing through the radiator, with the bottom hose being warm-to-hot too.
Temperature Gauge:
But still my temperature gauge sits well below the 70 degree mark - barely above minimum.
- The temperature gauge does fluctuate - sometimes visibly
- It never gets even close to 70 degrees
- It's not reliably at any position eg under load or at idle
Temperature Sensor
So my next suspect is temperature sensor. Where is this and is there a way I can test it?
There's these two plugs on top of the thermostat. (Un)plugging the green one clicks a relay on the left of the engine bay. (Un)plugging the blue one has no noticeable impact without the engine running.
